McMark |
Do any/all early 914/4 tailshifters come with the intermediate plate with provisions for the 914/6 throttle bellcrank? Or is the boss only found on 914/6 transmissions?
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
My 70 1.7 vin 29xx did and I still have that intermediate plate...stole those good gears for a rebuild.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Actually, a lot of them have the provision!
Geoff, No comments on the "club doings" ?? B |
McMark |
Good, I wanted to make sure I didn't cut the bellhousing off a 914/6 transmission. (IMG:style_emoticons/default/sawzall-smiley.gif)
Thanks Geoff. |
Bleyseng |
Actually, a lot of them have the provision! Geoff, No comments on the "club doings" ?? B I haven't had time to be in the Garage much due to "Work". Swamped right now...plus I am working of several MPS's...for 2056cc engines with 9550 cams. Those take alot of tuning work to set right. Ok, everything looks "GREAT" and glad to see the Ecomm is up and running plus Eric is a great choice. (IMG:style_emoticons/default/flipa.gif) |
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
making a motor stand/starter system? Also look to cut up a cracked case. Found one with cracks around the diff housing . Little hairline jobs. needed to clean the tranny (prep for paint) when it became visable. a solvent rince, followed by a dry wipe, and a dusting of powdered chaulk bropught out the crack much more to the eye. It followed around the external ribs on the tranny top above the diff.
tossed that case years ago, would have made a good engine test stand. oh well |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,709 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Good, I wanted to make sure I didn't cut the bellhousing off a 914/6 transmission. uhm, if i recall correct, that transmission did not just have the "provision", it actually had a threaded hole there, correct? could very well be an original 914/6 tranny you just cut up ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
My '71 tailshift and '74 sideshift both have it-----
Would that make the '74 a '71 parted out rebuild?? |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Good, I wanted to make sure I didn't cut the bellhousing off a 914/6 transmission. uhm, if i recall correct, that transmission did not just have the "provision", it actually had a threaded hole there, correct? could very well be an original 914/6 tranny you just cut up ... (IMG:style_emoticons/default/cool_shades.gif) Andy Some have the provision, some are already drilled. The one on my car had the provision only and I had to drill and tap it. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:39 PM |
