Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Have a MPS that I thought was a 1.7. Tried to check it by swapping with my other, but the plug is different.
Is this a 1.8? Part numbers are 0280100049 & 022906051E Attached image(s) ![]() |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
plug was different?
Whats the other type? |
Mikey914 |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
i would bet that since the connections to the MPS are simply to two inductors (think of an inductor as simply a helix of wire like if you wound a wire around a pencil), that there is no polarity to have to pay attention to so the plug could go either way. some plugs have a little "stop" in the corners of the opening for the plug that restricts the plug from being connected wrong.
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
There are 4 numbers on the connector on the MPS and the same 4 numbers on the harness connector. The numbers correspond to one another - and it should only go in one way. It *may* not make a difference, but the same holds true throughout the car and some connectors do only fit in one fashion.
JeffBowlsby |
Flip the connector, the MPS works the same either way.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 10:43 PM |
