silly Q, draining the oil out of a six |
pete-stevers |
Dec 30 2006, 09:09 PM
saved from fire! Group: Members Posts: 2,645 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
harlot is in need of fresh oil.....
but how does one drain the oil i have a coupled hose running from the tank....seperated but only on quart...er litre came out...what other stuff do i need to do.... if you poke fun.......i' ll getcha |
crresind |
Dec 30 2006, 09:53 PM
Newbie Group: Members Posts: 13 Joined: 8-June 04 From: Oceanside, California Member No.: 2,175 Region Association: Southern California |
You must also remove the sump plate, located in the center bottom of the engine. There are eight(8) nuts(usually). Loossen them, two at a time, starting to one side. Work your way around to the opposite side, leaving the plate slightly hanging down. Let her drain. When the bulk of the oil has drained, remove the plate and clean the plate and screen.
Joe Bob |
Dec 30 2006, 10:01 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Unless your tank is tapped for a drain plug, disconnect the oil line and drain from there....then the engine sump.....
pete-stevers |
Dec 30 2006, 10:58 PM
my thougths .....how about the oil in the oil cooler, does the thermostat let the oil drain out of the sys?
Joe Bob |
Dec 30 2006, 11:38 PM
Lo-Fi Version | Time is now: 26th December 2024 - 10:18 AM |
