Heat exchanger question |
1bad914 |
Jan 28 2007, 10:41 AM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
I have built a 1911, I have the option of putting early 1.7 heat exchangers on or putting later two piece exchangers on, what is the opinion, I have always had problems with exhaust leaks with the one piece system, I was thinking that the two piece system may be better since the j-pipe would install very easily. ???
Mueller |
Jan 28 2007, 10:47 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I have built a 1911, I have the option of putting early 1.7 heat exchangers on or putting later two piece exchangers on, what is the opinion, I have always had problems with exhaust leaks with the one piece system, I was thinking that the two piece system may be better since the j-pipe would install very easily. ??? if you mean the heat exchangers from a '75/'76 1.8 or 2.0, expect a loss of 4-8 hp and a increase in head temperatures..... trust me, the single piece is a PITA as well.... |
Brando |
Jan 28 2007, 02:03 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Scrounge the classifieds for a set of SSI 2.0 heat exchangers and heat hardware. They have a larger inside diameter than stock early 2.0 heat exchangers and should give you a wee bit of hp over those 4-2-1 late style heat exchangers.
Believe me, the backdate is worth it. You just gotta find all those little pieces. Or if you don't care for heat, a guy named ed (willowcreeklane) has what looks like a euro race header available in anaheim hills, ca. |
Joe Bob |
Jan 28 2007, 02:22 PM
Go with 73-74 HEs with the appropriate hanger and muffler.....only thing better is a header...but no heat.
1bad914 |
Jan 28 2007, 02:25 PM
I just sold a full SSI HE setup last year, This wil be a daily driver, I have access to multiple early 1.7 HE's, since my wife and I will be using this car as a weekend beach cruiser also(yes we have beaches in Michigan) (IMG:style_emoticons/default/smile.gif) I would like heat, so the one piece 1.7 HE with heat hardware will do the trick.
Thanks! |
ottox914 |
Jan 29 2007, 07:47 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Go to the for sale section and buy my SSI package, everything you need but the gaskets and a few bolts. PM me of you want. I'm in NW wisconsin, hopefully shipping wouldn't be to bad, or if you come down to the Mpls/st paul area for work or play, we could meet and do the deal.
r_towle |
Jan 29 2007, 09:36 AM
Custom Member Group: Members Posts: 24,659 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The stock 1.7 and 2.0 liter 72-74 all have the same size inner diameter of the tube,so the difference is the upturned end on the 1.7 setup, the flange on the end is different as well as the gasket/muffler connection.
They do require different muffler hangers, and different mufflers, and gaskets. The front side, head side/heat side is basically the same. Rich |
Bleyseng |
Jan 29 2007, 11:11 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Hmm, why the different size gaskets at the HE to muffler? I measured the stockers years ago IIRC inside diameter is bigger on the 2.0L HE.
Now on the SSI HE's the pipe is the same dimension inside with only the upturn at the end being the difference. |
r_towle |
Jan 29 2007, 11:16 AM
The inside diameter of the 1.7/1.8 versus the early 2.0 liter are the same. I have both on the floor.
the gasket is different cause the tubes are closer together on the 2.0 liter, and the flange is a different shape. They are close, but no cigar. Rich |
Lo-Fi Version | Time is now: 26th December 2024 - 12:53 PM |
