Seat belt retractor repair/replacement., I need a source to repair/replace my retractors. |
m_davidson |
Feb 14 2007, 01:29 PM
Newbie Group: Members Posts: 37 Joined: 20-November 05 From: Bellingham WA Member No.: 5,156 |
My 914 seat belt retractors don't work very well. I'd like to keep the retractable function. Does anyone repair the retractors? The belts and the rest of the harware seem okay.
Does anyone know anything about the eBay item # 330088556824 belts? Mel |
dagdal1967 |
Feb 14 2007, 01:36 PM
What are YOU looking at... Group: Members Posts: 372 Joined: 13-March 03 From: Carrollton, Texas Member No.: 423 |
My 914 seat belt retractors don't work very well. I'd like to keep the retractable function. Does anyone repair the retractors? The belts and the rest of the harware seem okay. Does anyone know anything about the eBay item # 330088556824 belts? Mel Those look interesting. I'd like to know about these too. I was talking to Clay the other day about seat belts and he said that 944 seat belts are pretty much bolt on replacement for the 914. He did say that there was a bolt or a shim that you had to cut off, but other than that, it was a direct replacement. |
BigDBass |
Feb 14 2007, 01:38 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
PEParts rebuilds seat belts. Linky!
boxstr |
Feb 14 2007, 02:00 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Sanke-Oyl they are in Texas, 1-800-284-7777 Their website is down becasue teir ISP went TU.
Great work. CCLINBUCKLEUP |
blitZ |
Feb 14 2007, 02:11 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I replaced my seat belts with some 924 belts. They work fine.
ClayPerrine |
Life's been good to me so far..... Group: Admin Posts: 15,965 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
My 914 seat belt retractors don't work very well. I'd like to keep the retractable function. Does anyone repair the retractors? The belts and the rest of the harware seem okay. Does anyone know anything about the eBay item # 330088556824 belts? Mel Those look interesting. I'd like to know about these too. I was talking to Clay the other day about seat belts and he said that 944 seat belts are pretty much bolt on replacement for the 914. He did say that there was a bolt or a shim that you had to cut off, but other than that, it was a direct replacement. The 944 seat belt is identical to aq 914 one with one exception. There is a big-assed pin on the 944 seat belt that sticks out the back of it. That pin has to be removed to install it in a 914. And I know a Red water pumper that really doesn't need seat belts because it never goes very fast... (IMG:style_emoticons/default/poke.gif) |
dagdal1967 |
Feb 14 2007, 02:16 PM
I know a Red water pumper that really doesn't need seat belts because it never goes very fast... (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) |
PinetreePorsche |
Feb 14 2007, 02:25 PM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
Anyone ever re-tension the belts? Is there any great chalenge--like can you just tighten a spring by winding it a little tighter? Isn't getting to it/getting it out half the battle?
dr914@autoatlanta.com |
Feb 14 2007, 02:34 PM
914 Guru Group: Members Posts: 8,113 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there are several aftermarket suppliers who still have old new stock in factory 914 seatbelts at very good prices (like dave at GPR!!) I would try them before substituting or going through a big hassle. Also if you pull them out completely and then lubricate the roller base with some of the stuff that penetrates and then turns to grease you may get them to work nicely again. (of course you will have to remove the retractor assembly from the car!)
Joe Ricard |
Feb 14 2007, 02:52 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
on my 1st 914 I got a set of nice belts from a 300D Mercedes, the rear belts worked nice. Made by REPA just the 914 units.
Now I just use my harnesses. Anyone ever re-tension the belts? Is there any great chalenge--like can you just tighten a spring by winding it a little tighter? Isn't getting to it/getting it out half the battle? I tried that with a old 74 Super Beetle. Funnest thing when that spring lets loose and goes everywhere. Like pushing a mad snake back in the bag pushing it by the tail. |
McMark |
Feb 14 2007, 04:33 PM
I've tried retensioning. It didn't work. I'm convinced that 'lazy' seatbelts are caused by two factors:
1) corrosion/rusting of the chrome guide that sticks out the top and the top pivot/attachment guide by the coat hook. I see so many of those with peeling chrome and therefore lots of sharp edges to 'grab' the belt webbing. 2) Frayed belt webbing. there are companies out there that will put new webbing on your old belts. They even match the original stitching and sew on the old tags. Frayed webbing is a safety concern and any seat belt manufacturer will tell you that. Here's a picture of the 944 belts with the big pin knocked off, the resulting hole tapped, and the original 914 pointy pin threaded in. And here's how they look in the car. Very original. |
Bartlett 914 |
Feb 14 2007, 04:35 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Just a word about taking them apart. It can be a little dangerous. The spring really wants to fly apart. Not too easy to put back together. I ended up tossing mine.
McMark |
Feb 14 2007, 04:40 PM
Yeah, don't take apart the skinny side unless you know what you're doing. It will erupt violently and dangerously and in most cases, becomes trash. |
m_davidson |
I've had the retractors out of the car but lack the courage to unwind the spring and rewind it tighter. I'll try oiling them up better, but I suspect the springs are just tired from 35 years of service, and it's time to replace.
Keep those cards and letters coming. Mel |
will |
Feb 14 2007, 05:35 PM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
there are several aftermarket suppliers who still have old new stock in factory 914 seatbelts at very good prices (like dave at GPR!!) I would try them before substituting or going through a big hassle. Also if you pull them out completely and then lubricate the roller base with some of the stuff that penetrates and then turns to grease you may get them to work nicely again. (of course you will have to remove the retractor assembly from the car!) Just got off the phone with Dave at GPR. He said he has about 10 good used pairs of seat belts at 50 dollars a piece plust 6 dollars shipping. No NOS. |
Feb 14 2007, 05:48 PM
there are several aftermarket suppliers who still have old new stock in factory 914 seatbelts at very good prices (like dave at GPR!!) I would try them before substituting or going through a big hassle. Also if you pull them out completely and then lubricate the roller base with some of the stuff that penetrates and then turns to grease you may get them to work nicely again. (of course you will have to remove the retractor assembly from the car!) Just got off the phone with Dave at GPR. He said he has about 10 good used pairs of seat belts at 50 dollars a piece plust 6 dollars shipping. No NOS. He has them. Ask him about his friend George's new old stock of over 300 of each side that he has access to sell. |
StratPlayer |
Feb 14 2007, 08:00 PM
StratPlayer Group: Members Posts: 3,300 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Feb 15 2007, 11:02 AM
Just got off the phone with Dave at GPR. He said he has about 10 good used pairs of seat belts at 50 dollars a piece plust 6 dollars shipping. No NOS. What kind of price are the NOS? the set of nos is 250.00 for both |
will |
Feb 15 2007, 10:27 PM
Just got off the phone with Dave at GPR. He said he has about 10 good used pairs of seat belts at 50 dollars a piece plust 6 dollars shipping. No NOS. What kind of price are the NOS? the set of nos is 250.00 for both Does that mean 125 for each side? I'll take the driver side if you have one George, please. thanks, will |
will |
Feb 17 2007, 07:13 PM
Just got off the phone with Dave at GPR. He said he has about 10 good used pairs of seat belts at 50 dollars a piece plust 6 dollars shipping. No NOS. What kind of price are the NOS? the set of nos is 250.00 for both Hey George, I called and got my seat belt set for 285. Thirty five dollar difference (IMG:style_emoticons/default/dry.gif) . I've been looking for new seat belts for a while now and glad you have them. thanks, will |
Lo-Fi Version | Time is now: 4th January 2025 - 06:24 PM |
