Wheel Lock Identification, Help us out. |
Series9 |
Feb 19 2007, 08:03 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Nelson discovered this weekend that he does not have the socket to remove his 968 wheels.
Can you ID this lock? Advice on getting the key? Attached image(s) |
plymouth37 |
Feb 19 2007, 08:28 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
If all else fails try something like this:
wheel lock remover I think they sell a cheap version at napa. They work great, rim thiefs love 'em. |
Crazyhippy |
Feb 19 2007, 08:32 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
I've used "reverse EZ outs" (sears or snap-on truck) to pull those before, not sure you have the room to get them on though....
I believe those are factory wheel locks though, maybe the stealership will have a master key? BJH |
Crazyhippy |
Feb 19 2007, 08:33 PM
Aaron Cox |
Feb 20 2007, 01:42 AM
when i 'steal' wheels (at a junkyard)
we take a socket that almost slides on... and use a BFH to beat it on... then break em loose (IMG:style_emoticons/default/smile.gif) kill a cheap socket.... |
Twystd1 |
Feb 20 2007, 02:12 AM
You don't want to know... really..... Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Is that the lock with the spinning head??????
If so...... I would drill it... for sure. If the head doesn't spin.... Either use a socket A'La'Aaron or find a buddy with the snap on removal tool.... They work like a charm. If all else fails. Weld a big ass bolt to it and turn it off....... Tape off the wheel are before welding... Or put wet rags around weld area.... Sparks pit wheels... C |
Brando |
Feb 20 2007, 02:53 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
take the plastic cap off first.
key goes in, twist, take the cap off. if not, drill it out. shit, nevermind... check the glove box for the socket? |
Lo-Fi Version | Time is now: 4th January 2025 - 08:35 PM |
