ahdoman |
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California ![]() |
Anybody got a good way to remove paint overspray from seals w/o damaging the rubber? Not my bad - previous owner so paint has been there awhile.
Attached image(s) ![]() ![]() |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
I know this might sound a bit absurd however I'm quite serious... try "creamy" peanut butter. Does wonders for removing wax from rubber & black plastic. Can't hurt the seals/rubber/etc... (IMG:style_emoticons/default/cool_shades.gif)
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I've used both acetone and paint stripper.
The acetone I've dampened a cloth and rubbed until the paint released. I think paint stripper uses acetone along with some jell stuff to keep the active ingredients from evaporating too fast. Spoke |
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
Lacquer thinner? Test and make sure it doesn't eat the rubber. Whatever you use wear rubber gloves!
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
If you can remove them from the car, soak them in Simple Green. This will make the paint come right off, and it rejuvenates the rubber nicely, too.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
or goof off and steel wool.
Rich |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
I have used lacquer thinner and fine steel wool many times with great results. Frankly, I usually didn't use gloves but probably should have.
Goof Off is also a great product, but I'm not sure it will work on all paints. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
If you can remove them from the car, soak them in Simple Green. This will make the paint come right off, and it rejuvenates the rubber nicely, too. i send my seals to a health spa when they need rejuvenation (IMG:style_emoticons/default/chairfall.gif) |
vertigo |
Member ![]() ![]() Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 ![]() |
I use the cheap autozone carb cleaner (1.19/can). Have no idea if it is actually good for carburator, but for removing paint it is great.
Lo-Fi Version | Time is now: 26th June 2024 - 04:25 AM |
