RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
Last night,I ripped of the rear fiberglass flares to make way for the steel units from the group buy a last month. Fronts are completely done,now the rears. The rears are gonna widened about 2" per side,to cover the 10" wide wheels. As you can see in the pics,I have a few holes to fill,but that's not a big deal,that's why I have a welder. (IMG:style_emoticons/default/welder.gif) Ron Attached image(s) ![]() ![]() ![]() |
RON S. |
Last one,
Driver's side tacked. Ron Attached image(s) ![]() |
michaelt55 |
Graduate of Life's experiences ![]() ![]() Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None ![]() |
RON S. |
One note to all those interested. A 930 turbo brake setup DOES fit under 15" wheels.You can see'm peeking out from under those old ATS wheels in the last pic. Ron |
STL914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,195 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest ![]() |
One note to all those interested. A 930 turbo brake setup DOES fit under 15" wheels.You can see'm peeking out from under those old ATS wheels in the last pic. Ron With that turbo brake set up, you may want to keep those "scoops" in front of and behind the flares. (IMG:style_emoticons/default/laugh.gif) |
RON S. |
Moving right along,I got the holes in the quarter panels around the flares plugged over the weekend.
I'll spend this week welding everything up solid. (IMG:style_emoticons/default/welder.gif) Hopefully by this weekend,I'll be cutting the flares again to widen them. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) Stay tuned. Ron (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() ![]() |
tdgray |
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None ![]() |
WOW that is a lot of work... nice job.
RON S. |
This weekend was a good one for the old flare switch.
Got the repo flares cut and started the 2" widening process. The amount needed to widen is shown in the photo with tire on sticking out past the stock flare. Tire is a 265, on a 18X10 rim w/a 40MM offset setting on a 2" spacer. Ron Attached image(s) ![]() ![]() ![]() ![]() |
RON S. |
Moving right along, I widened the rears a full 2" on each side.
Then it was just cut and fit from there. My finished width is within 1/8' from either side. Ron Attached image(s) ![]() ![]() ![]() ![]() |
RON S. |
lastly, some back shots when I stopped work Sunday evening. R Attached image(s) ![]() ![]() |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
Insanity! (IMG:style_emoticons/default/thumb3d.gif) Beautiful creativity on those rear flare extensions. (IMG:style_emoticons/default/sawzall-smiley.gif) Wow, well done! (IMG:style_emoticons/default/welder.gif)
(IMG:style_emoticons/default/cool_shades.gif) |
RON S. |
I'll say this, This is the first,and last time I'll ever take on a modification of this size ever again. I'm getting to old for this @#it. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Ron |
RON S. |
This past weekend was another good weekend for working on the teener.
Weld work is pretty much done now,and I've almost got the passenger side of the car smoothed out. Drivers side will be ready to start mudding it up in a week or 2. Ron Attached image(s) ![]() ![]() ![]() |
RON S. |
If anyones wondering about clearance,I think I have some to spare if anyone needs some. R (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
RON S. |
Lastly,I'll show the trick to keeping the clearance stable throughout all the welding. I made these fender jacks from angle iron,1/2" pipe,1/2"threaded rod,and some nuts and washers. It worked perfectly. Ron Attached image(s) ![]() ![]() |
nomore9one4 |
Member of the Eastcoast Thread Killers Club ![]() ![]() ![]() ![]() Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None ![]() |
Nice job Ron! That looks sweet! You made it look so simple but we all know better. Can't wait to see it with color.
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
Incredible, Ron! How do you finish your welds on the inside of the fenders. Do you grind them down, or just shoot them with primer?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,191 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
very nice display of craftsmanship! (IMG:style_emoticons/default/smash.gif)
(IMG:style_emoticons/default/smilie_pokal.gif) Andy |
tdgray |
You do insane work. Well done. Bravo!!!
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Wanna sell the fiberglass ones???
Rich |
Lo-Fi Version | Time is now: 20th April 2025 - 02:59 AM |
