Rack Boots |
Rack Boots |
kconway |
Apr 4 2007, 08:08 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I was trying to save a buck (IMG:style_emoticons/default/chair.gif) and bought a turbo tie rod set (Lemforder) off ebay. Unfortunately, it came with mismatched rack boots. One was shiny, the other matt black. I recall one was more desirable then the other but can't remember which one. Does PP sell the good boots indivdually? I'm guessing the seller's gonna tell me to pound sand so want to see if I can buy the boot separately...there goes the few pennies I tried to save (IMG:style_emoticons/default/headbang.gif)
Kev |
So.Cal.914 |
Apr 4 2007, 09:27 PM
If both boots are in good shape and will protect the rod ends then I would
put them on, know one will see them except maybe a slow moving cat as you pass over it. |
kconway |
Apr 4 2007, 10:33 PM
Not worried about esthetics of the boot or even what that cat thinks (IMG:style_emoticons/default/happy11.gif) . I am worried about replacing an inferior boot after several hundred miles, especially AFTER I get the alignment done...
IronHillRestorations |
Apr 5 2007, 07:26 PM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
As long as you didn't change the length of the tie rod end you should be able to disconnect and reconnect to swap the boot.
BMartin914 |
Apr 5 2007, 08:28 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
As long as you didn't change the length of the tie rod end you should be able to disconnect and reconnect to swap the boot. (IMG:style_emoticons/default/agree.gif) |
kconway |
Apr 5 2007, 10:10 PM
Ehhh, ebay vendor is being cool about it and says he's gonna send me the "right" boots...So...which are the "right" boots or did I just imagine that there is a difference???
Lo-Fi Version | Time is now: 26th June 2024 - 04:54 AM |
