jjs3rd914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 ![]() |
It all started when wanting to reinstall the battery tray back in stock position. A PO had put battery in rear trunk and fiberglassed over the "hell hole". Of course the more we dug the worse it got. We have completed the upper area repair inside engine compartment and now ready to install the Restoration Design (RD) outer clamshell overlays. All the major repair threads show the removal of the lower portion of the fender get full access. We really do not want to do this unless this is the only way to correctly install the pieces so they will work as designed.
Has anyone installed the RD overlays (or Brad's system) without cutting away the fender for access? If so how did you do it? It would appear that a very small MIG gun (anyone know of such a tight area gun?) would help, but one still would not get to all the critical areas that need welded inside the fender. Are we indeed doomed to cut the fender piece, reweld and repaint? The car was just painted by the last PO. Thanks, and thanks to all the previous posts on repairs. jjs3rd914 |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
It all started when wanting to reinstall the battery tray back in stock position. A PO had put battery in rear trunk and fiberglassed over the "hell hole". Of course the more we dug the worse it got. We have completed the upper area repair inside engine compartment and now ready to install the Restoration Design (RD) outer clamshell overlays. All the major repair threads show the removal of the lower portion of the fender get full access. We really do not want to do this unless this is the only way to correctly install the pieces so they will work as designed. Has anyone installed the RD overlays (or Brad's system) without cutting away the fender for access? If so how did you do it? It would appear that a very small MIG gun (anyone know of such a tight area gun?) would help, but one still would not get to all the critical areas that need welded inside the fender. Are we indeed doomed to cut the fender piece, reweld and repaint? The car was just painted by the last PO. Thanks, and thanks to all the previous posts on repairs. jjs3rd914 We developed and designed the rocker clam shell for restoration design (medium lengthed very sad story) and it is designed to install without removing the quarter panel or anything else except maybe the sill panel if one is so inclined but not absolutely necessary. We developed a great tech installation procedure for the clamshell. |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
QUOTE We developed a great tech installation procedure for the clamshell. (IMG:style_emoticons/default/popcorn[1].gif) |
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
QUOTE We developed a great tech installation procedure for the clamshell. (IMG:style_emoticons/default/popcorn[1].gif) OK, where's the tech installation procedure?????? (IMG:style_emoticons/default/aktion035.gif) -- Rob |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
One of the Dr.'s 700 914 Tech Tips?
jjs3rd914 |
We already have removed the door threshold sill and are in the process of fitting the clamshell overlay. As we pointed out in our inital post the welding of the top of the overlay inside the fender is going to be a challenge. It looks like if the rear trailing arm and suspension are removed it would allow one to sit inside the fender well and take a stab at the welding (if one is right handed). The car is on a four post lift. Another issue is the removal of the upper portions of the remnants of the old jacking plate (new ones will be installed) as they are at the tighest spot.
Dr. 914 or anyone else, we would be very interesed in the detailed technical instructions referenced to guide us through this. In fact just today we ordered the triangle supports from AA to reinstall the sill correctly. Thanks, jjs3rd914 |
r_towle |
Get a sawzall and a 4 inch grinder.
For the top of the jack post its a combination of the two and a hand chisel to get the remaining piece off. For the welding of the top part of the overlay under the fender, it can be done with the suspension in place, but as you said,,it takes time and patience. Drill some holes right up near the top and you can reach those to spot weld the top in place. It is not easy, but certainly can be done. If you think of one more idea, cut a section of the fender away, approx. 8 inches of the bottom of the fender, stay one inch away from the door for the vertical cut, and take out this piece. From there do the overlay welding, sitting up/or standing in your case. Then take the same piece you cut out and weld it back in place.. If you use a very thin blade, you will only remove 1/16 of an icn of material, and when you go to re-install, clamp it with a 1/16th inch gap to get it to line up like stock, welding rod/wire will fill in that gap. If you go this direction, weld only one inch at a time, then rest...let the metal cool naturally. When I do these body panel type welds, I have other things to do, so it may take me two days to complete that 12 inches of welding...but this way I never over heat the fender and warp it. You may need to hammer and dolly the weld the flatten it back out...it tends to curl in both the fender and the piece in the weld area...just work slow, hammer and dolly each time you weld and you can control the movement pretty well. And when you grind, again...take breaks...let it cool down.. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 08:11 AM |
