finals for installing the mallory, do i have this correct? |
rhodyguy |
Apr 22 2007, 01:59 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i marked the dist housing @ the #1 wire position. for practice i turned the old engine to the point where the flywheel mark is at the top, centered on the case parting line. slack on i&e valves. if i do the same on the new engine, set the dist rotor to the marked line and slide it in, this should get me in the ballpark for spark?
k |
Brando |
Apr 22 2007, 03:17 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
You could have that distributor rotated 270ยบ for all it cares... As long as you're setting your static timing with the engine on TDC #1 and the rotor pointing to the #1 Mark and your wires are in the right order.
Aaron Cox |
Apr 22 2007, 04:45 PM
rhodyguy |
Apr 22 2007, 07:34 PM
i left the dist clamp on the mallory when i pulled it, so i think getting to tdc on 1 and bolted in everything should be fine for the fire up. thanks guys.
k |
Lo-Fi Version | Time is now: 21st September 2024 - 06:50 PM |
