gas tank |
gas tank |
Howard |
Dec 3 2003, 10:59 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Is there any difference between an early (midship pump) and late (front pump) fuel tank?
skline |
Dec 3 2003, 11:02 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I know the top fuel fill is different, the early having metal expansion tank as opposed to a plastic one on the late models.
Howard |
Dec 3 2003, 11:28 PM
have a 73 with possible rust issues in tank. will later tank fit?
Joe Ricard |
Dec 4 2003, 07:23 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Howard I just pulled out the tank on my 74. It looks really good no rust issues. Right now it is set up for carbs but the plug can easily be removed on the return line.
JFJ914 |
Dec 4 2003, 04:44 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The tanks have different P/N's but I think the only difference between them are the brackets for the vapor canister. Other than that they are interchangable after you change the outlet tube to suit your particular fuel pump setup.
Howard |
Dec 4 2003, 05:29 PM
Thanks, John. Joe, I'm not sure it's bad, and think I have one locally. Will contact you if I need it.
Gint |
Dec 4 2003, 06:23 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE have a 73 with possible rust issues in tank. will later tank fit? Yes. And you can easily use the tank filler top and also the expansion chamber (if the original car/tank had one) from the original tank if you prefer. |
Lo-Fi Version | Time is now: 21st September 2024 - 07:06 PM |
