a quick torque value please, heat ex to head nuts |
rhodyguy |
Apr 25 2007, 06:54 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
they went on smooth as silk. just need to tighten them down. thanks ya'll (IMG:style_emoticons/default/thumb3d.gif) .
k |
Chris Pincetich |
Apr 25 2007, 07:13 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Purely from memory - lets see if I am perma (IMG:style_emoticons/default/smoke.gif)
17 lbs (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Apr 25 2007, 07:28 PM
Whatever the torque spec is, odds are it'll need to be tighter. I run 'em and do the final tightening while it's hot (and running). The Cap'n
Allan |
Apr 25 2007, 07:35 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I run 'em and do the final tightening while it's hot (and running). The Cap'n On jack stands... (IMG:style_emoticons/default/av-943.gif) |
DanT |
Apr 25 2007, 07:39 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
On Tunacan they say 14#s. I set mine to this setting cold during build and will retorque to a slightly higher setting once the motor is warm and the cam is broken in...while the motor is still pretty warm...
type47 |
Apr 25 2007, 09:44 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i asked the same question a long time ago and Jake said 18 ft-lb
Lo-Fi Version | Time is now: 25th June 2024 - 04:49 PM |
