Momo Adapter Eary vs Late, What's the difference? |
tyler |
Apr 26 2007, 03:39 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
This adapter was sold to me as an "early" but it's obviously the wrong one. It doesn't sit far enough down on the column shaft for the directional signal cam to make contact. And there's a major gap.
Can someone confirm that the adapter for the early is made to set further down on the column shaft and that the one I have is for a late model? Thanks, Attached image(s) |
tyler |
Apr 26 2007, 03:40 PM
One more pic........
Attached image(s) |
Aaron Cox |
Apr 26 2007, 05:37 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
PN 8002 is the late one IIRC
what is the PN on yours? |
Dr Evil |
Apr 26 2007, 05:41 PM
Send me your transmission! Group: Members Posts: 23,035 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
8002 is for the later solid type one, not the webed type that Tyler has. I am not sure of the difference, though, in fit.
Lightweight_911 |
Apr 27 2007, 04:14 AM
Member Group: Members Posts: 71 Joined: 7-October 06 From: London, UK Member No.: 7,008 |
As already stated the part # for the '72-'76 models is 8002 - the earlier one for '70/'71 models is 8000
tyler |
Apr 27 2007, 10:49 AM
I took a closer look. Where the wheel attaches, it's stamped "MOMO" and "TOP".
The base has been painted but I can make out a stamp on it that looks like "L 231". Also the spline does fit ok. It doesn't match the pictures I see for the later one so maybe I'll play with it some more today. If the directional cam happens to reach, which I doubt, could I be missing a cover piece on the column? |
tyler |
Apr 27 2007, 10:59 AM
Well, according to this: http://www.cardomain.com/item/MOM231, this 914 adapter I bought is for a:
Applications * 1974-2005 PORSCHE 911 * 1978-1979 PORSCHE 930 No wonder it has a strange fit. |
Aaron Cox |
Apr 27 2007, 11:17 AM
well... when you put a 911 or 944 steering wheel on a 914, there tends to be about a half inch gap...... you are in the same boat
dbu356 |
Apr 27 2007, 11:33 AM
Member Group: Members Posts: 120 Joined: 2-May 04 From: Scottsdale, AZ Member No.: 2,013 |
Checking hub application guide at http://www.ltbmotorsports.com/hubkit.html shows:
Porsche 911, 911 Carrera, 930 Turbo 8/74-03 L231 David I took a closer look. Where the wheel attaches, it's stamped "MOMO" and "TOP". The base has been painted but I can make out a stamp on it that looks like "L 231". Also the spline does fit ok. It doesn't match the pictures I see for the later one so maybe I'll play with it some more today. If the directional cam happens to reach, which I doubt, could I be missing a cover piece on the column? |
Lo-Fi Version | Time is now: 4th January 2025 - 06:54 PM |
