Need advice for brakes OT, Eric Shea? Anybody? |
michaelt55 |
May 4 2007, 03:10 PM
Graduate of Life's experiences Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None |
Need some help, a friend of mine has a custom kit car and wants to know if a type I VW and a 914 master cylinder are interchangeable? If so, could a 19 mm one be used? Also anyone have a preference on types or brands of proportionaing valve to use that is adjustable? Would like to change the bias to 70-30....
Michael |
Matt Romanowski |
May 4 2007, 03:35 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The MC is not sold as interchangable.
michaelt55 |
May 4 2007, 03:39 PM
ok...let me elaborate so as not to be too obvious....
has anyone modified or used these combo's?? I know they are not sold as interchangable... but then half the things we see on this site are from adaptation or modification...I have a porsche with BMW calipers... (IMG:style_emoticons/default/dry.gif) Anyone have a better solution? Michael |
Eric_Shea |
May 4 2007, 03:42 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What brakes (calipers) will he be using?
michaelt55 |
May 4 2007, 03:46 PM
Stock 914's Eric.... question is...will it hook up to a stock pedal set from a type I or will he need to go all out with ONeals?
If he is stuck with the type I pedals...I thin he can use a Type II MC...but do you know of a good valving system to get his 70/30? What brakes (calipers) will he be using? |
Eric_Shea |
May 4 2007, 03:55 PM
Could he sandwich a 914 or 911 cluster in there? The T1 M/C will not work.
Lo-Fi Version | Time is now: 26th June 2024 - 04:09 AM |
