JBart |
UNDER CONSTRUTION ![]() ![]() Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 ![]() |
I need some help here I took my fan off to replace the oil cooler seals and the bolts are different along with the looks of the fan itself . The first picture is the fan off of my 72'. The second fan is off ? it came with a box o parts. The part # of the second fan is 021 119 113 the fan off my car has no part #.
One of the 12pt. bolts on my car was stripped so I either need to find the same 12pt. bolts or can I switch the fan out so I can use regular hex head bolts either way is fine by me I just need to find the 12pt. bolts I didn't see any at PP Thanks, jbart Also there is a picture of the bolt from my car. Attached image(s) ![]() ![]() ![]() |
RustyWa |
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 ![]() |
Looks like a fan that came on a car with a smog pump. The pully extension would bolt up to that location.
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
The second fan, on the right, looks exactly like the one on my 71 1.7. Joe O
I need some help here I took my fan off to replace the oil cooler seals and the bolts are different along with the looks of the fan itself . The first picture is the fan off of my 72'. The second fan is off ? it came with a box o parts. The part # of the second fan is 021 119 113 the fan off my car has no part #. One of the 12pt. bolts on my car was stripped so I either need to find the same 12pt. bolts or can I switch the fan out so I can use regular hex head bolts either way is fine by me I just need to find the 12pt. bolts I didn't see any at PP Thanks, jbart Also there is a picture of the bolt from my car. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
i have used both on mine.
i believe i read something on STF about the left one being slightly more efficient? |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
How do you work on a 914 and keep a fingernail that long and clean? (IMG:style_emoticons/default/ohmy.gif)
JBart |
SO if I use the flat fan instead of the coned fan what kind of bolt should I use just a regular 8mm bolt or is there a special type of bolt?
Thanks, jbart |
TheCabinetmaker |
regular bolt. Correct length is important. not sure about hardness of bolt.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
My car has the second type of fan, but also uses CV joint bolts like the first type does. The Kap'n has said not to switch around types of bolts, but I'm not sure why.
--DD |
JBart |
Thanks guys,
I went to the local VW shop and she had some CV bolts so hopefully mon. after work I can play with it and see if they are going to work they are a lil' longer so I might need to cut them down a little to make them work. As far as the pretty nails you should see my DRESS!!!!! (IMG:style_emoticons/default/smile.gif) Really thats where the wife comes in real handy "taking pictures" I point she shoots. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
I was told one was early and one was on later cars. The one with the rubber boobie and slope to the fan blades should be the more efficient one.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
The 'cone' fan came on early 1.7 motors. It uses shorter bolts that will not work with the late style fan. And conversely, the late style bolts are too long for an early fan. That being said, the only two factors you need worry about for bolts is thread engagement (not too short) and protrusion into the front main seal (not too long). Other than that it's a plain ol' 8 x 1.25 bolt.
Lo-Fi Version | Time is now: 26th June 2024 - 06:37 AM |
