> It's Alive! Vol III, The teener is running... better
BahnBrenner914
post Jun 22 2007, 03:10 AM
The girl is gone and all I have now is a beat-up teener
From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL
Well those following my story, the teener was running really crappy and sluggish after a couple miles down the road. So I replaced the fuel filter (IMG:style_emoticons/default/smash.gif) and unkinked the lines.
So I took it out (IMG:style_emoticons/default/driving.gif) and drove around for quite a while, around the block and then around a bigger loop by my house, and it kept running. It didnt totally crap out like it was before (IMG:style_emoticons/default/w00t.gif) , so that's good. It is still surging a little at 50+% throttle, but its driveable. (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif)
I havent checked the plug wires or the coil wire yet, but are there any other causes of surging power?
914nerd
post Jun 22 2007, 10:29 AM
Who you callin' a "Member"?
Well, is it still FI?
If it is, you could have a FI problem (and I will defer to the experts on that one)
The real question is why is that 914 not on jackstands where it belongs?
effutuo101
post Jun 22 2007, 10:38 AM
I had a bad aux air pump that caused my surges. take the TPS apart and clean it.
highways
post Jun 22 2007, 01:19 PM
QUOTE(effutuo101 @ Jun 22 2007, 09:38 AM) *
doesn't the factory manual say 'don't remove the TPS'? Isn't it super sensitive the adjustment on how it is positioned- and therefor hard to re-install correctly without some fancy test equipement? I dunno cause I haven't done it- but I was reading up on it lately and it doesn't look easy.
BahnBrenner914
post Jun 22 2007, 01:42 PM
I did take the AAR out (IMG:style_emoticons/default/sawzall-smiley.gif) and then put it back in (IMG:style_emoticons/default/smash.gif) cause I thought it was un-gunked (IMG:style_emoticons/default/barf.gif) , but maybe its an electrical problem (IMG:style_emoticons/default/happy11.gif) (cause it was reading 12 or so volts, but I couldnt get a reading for amps on it, and yes I know to put it in-line for amps (IMG:style_emoticons/default/alfred.gif) ). Does anyone know how many amps should be running through the AAR? maybe my multimeter doesnt have enough range. I'll clamp the AAR hose and take it for a drive (IMG:style_emoticons/default/driving.gif) and see if that does anything.
Things arent so good anymore, find the next topic "Hold the Phone... Vol. IV"
- Lo-Fi Version Time is now: 5th January 2025 - 12:19 AM
