Loser_Cruiser |
Member ![]() ![]() Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest ![]() |
Can any one help trace down the cause of my high fuel pressure? its reading at 80psi with just the key turned to the on position and cranking. I ve tried adjusting the regulator both ways and doesnt make a change in the pressure. Its a 76 2.0 with a 74 motor(still has 76 fuel injection but with out the egr stuff). THANKS!!
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
Not sure whether it would read pressure that high but..... Could your return line be kinked or blocked?
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
Can any one help trace down the cause of my high fuel pressure? its reading at 80psi with just the key turned to the on position and cranking. I ve tried adjusting the regulator both ways and doesnt make a change in the pressure. Its a 76 2.0 with a 74 motor(still has 76 fuel injection but with out the egr stuff). THANKS!! Thats high, assuming its reading correctly and you have a fuel return line check it for restrictions / kinked hose. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Your fuel lines are hooked up backwards or you have a kink in the return line.
Loser_Cruiser |
it was kinked. I asked my dad to make sure that it wasnt last week when we put the tank back in but i guess it was cause i found it right at the tank fitting. Thank you. Now i just need to clean my spark plugs up since it was running so rich and hope thats the last of the problems.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
it was kinked. I asked my dad to make sure that it wasnt last week when we put the tank back in but i guess it was cause i found it right at the tank fitting. Thank you. Now i just need to clean my spark plugs up since it was running so rich and hope thats the last of the problems. famous last words! |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Loser_Cruiser |
well im sure its not the last but at least the last that prevent me from diving it regularly. its been about a month so im in need of a fix. Right now its shooting flames occassionally, which to me is cool but my mom and dad arent too hot on it so got to get it under control. Im hoping its just loaded up in the intake and the exhaust and that tomorrow it will stop that. other wise its time to start trouble shooting again.
bd1308 |
I tried for three years to make the 914 a DD, just didnt work out well for me (getting really expensive and hard to find parts for).
Loser_Cruiser |
Yeah im starting to see why it would be hard to have it as a DD. since i bought it its been my DD though and this last month has been hard. the replacement has been a jeep wrangler nice car but not really a car more of a truck.
Lo-Fi Version | Time is now: 30th June 2024 - 11:42 PM |
