jus took my 914 v8 for inspection, and passed on hc 514 out of 600 |
jimkelly |
Jul 20 2007, 02:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
but failed on co's 6.84 out of 6.00.
nappa dude suggested i retard the dist 1/4 inch. also suggested maybe removing the air cleaner just for the emissions test. any comments?? jim |
skline |
Jul 20 2007, 03:02 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
If you have to do an emissions test, do what ever you have to do to make it pass and then change it back afterwards. How often do you have to do it?
jimkelly |
Jul 20 2007, 04:11 PM
every two years - not bad - jim
Mikey914 |
Jul 20 2007, 04:34 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Run the gas down til you get the idiot light. Add 1 Qt denatured alchol run it through then fill the tank after to dilute. It burns with out producing CO, and is used on board boats because of that. However it is not good for certian kinds of plastics, so you will not want it in your tank for very long. (IMG:style_emoticons/default/happy11.gif)
jimkelly |
Jul 20 2007, 04:45 PM
denatured alcohol - thanks
i have been told this by a local buddy but he warned the same thing about the damage it can do to rubber and plastics. thanks jim |
Gint |
Jul 20 2007, 06:14 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I've gotten a few carb'd cars (still have a one of my old Chevy trucks laying around in addition to 914's) through testing that were on the edge of CO by retarding the timing a tad.
jimkelly |
Jul 20 2007, 06:24 PM
Gint |
Jul 20 2007, 06:33 PM
cool - so i was not wrongly advised - will try that - that - jim I've gotten a few carb'd cars (still have a one of my old Chevy trucks laying around in addition to 914's) through testing that were on the edge of CO by retarding the timing a tad. Just a little, don't go crazy. You're not far off anyway. Changing the timing may very well affect your HC a little bit too. If it costs you to have the thing tested every time it might be worth it to pay a shop this time for 30 minutes labor to put it on an analyzer and adjust it to pass. Or find someone that has an analyzer. Then you can tune for performance after the test and make notes on what timing and mixture settings it took to get it to pass so 2 years down the road you can tweak,test, re-tune and be done. |
jimkelly |
Jul 20 2007, 06:41 PM
nope - no charge to have it retested.
jim -- cool - so i was not wrongly advised - will try that - that - jim I've gotten a few carb'd cars (still have a one of my old Chevy trucks laying around in addition to 914's) through testing that were on the edge of CO by retarding the timing a tad. Just a little, don't go crazy. You're not far off anyway. Changing the timing may very well affect your HC a little bit too. If it costs you to have the thing tested every time it might be worth it to pay a shop this time for 30 minutes labor to put it on an analyzer and adjust it to pass. Or find someone that has an analyzer. Then you can tune for performance after the test and make notes on what timing and mixture settings it took to get it to pass so 2 years down the road you can tweak,test, re-tune and be done. |
drive-ability |
Jul 20 2007, 10:22 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Jim,
If you were to lean out the idle system a bit, team that with a 4 to 6 degree retarding of the timing. Doing that together may keep your HC from spiking. I assume you are doing an idle and cruse test? For the cruse portion I would install a new air-filter, make sure the choke plate is open all the way and you may be good to go. Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif) |
scotty b |
Jul 20 2007, 11:30 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
any comments?? jim Move (IMG:style_emoticons/default/chairfall.gif) No emissions testing in Richmond (IMG:style_emoticons/default/poke.gif) |
jimkelly |
Jul 21 2007, 06:25 AM
the test is only at idle.
i am not changing engines but do wonder how well a brand new crate 350 from paceperformance would emissions wise with the right components?? http://paceperformance.com/index.asp?PageA...p;ProdID=154046 jim Jim, If you were to lean out the idle system a bit, team that with a 4 to 6 degree retarding of the timing. Doing that together may keep your HC from spiking. I assume you are doing an idle and cruse test? For the cruse portion I would install a new air-filter, make sure the choke plate is open all the way and you may be good to go. Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif) |
drive-ability |
Jul 22 2007, 01:35 AM
[quote name='jimkelly' date='Jul 21 2007, 05:25 AM' post='926311']
the test is only at idle. i am not changing engines but do wonder how well a brand new crate 350 from paceperformance would emissions wise with the right components?? Jim, I have a new GM crate motor much like that in my V8 car and it really runs great! I have no emission testing here in Ca. but surely it would help to have a fresh set of valves. Your carb and ignition systems would likely still cause the engine to fail, you just need an adjustment or two. (IMG:style_emoticons/default/driving.gif) |
JPB |
Jul 22 2007, 09:17 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Crap! Sorry to hear that. Can't you just get Antique tags and bypass the whole emission scam deal? If all else fails, sell the car to me (IMG:style_emoticons/default/biggrin.gif)
scotty |
Jul 22 2007, 12:02 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif) Soooo right! I feel guilty in my car for the first block...after that (IMG:style_emoticons/default/rocking nana.gif) and I just have a carbed /6! |
Brando |
Jul 22 2007, 04:59 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Running any emissions control on the exhaust side?
Also heard of running a quart of acetone to help with bringing down levels... Never tried, we tune our cars to pass if asked and paid to. |
jimkelly |
Jul 22 2007, 05:06 PM
nope - in delaware a car has to be 1968 model year or older - it is not like in VA where a car has to be 25 years old or older : (
i will get it thru though this or next week. jim Crap! Sorry to hear that. Can't you just get Antique tags and bypass the whole emission scam deal? If all else fails, sell the car to me (IMG:style_emoticons/default/biggrin.gif) |
jimkelly |
Jul 22 2007, 05:14 PM
nope - no emissions at all
denatured alcohol is what I heard - i am gonna run my gas tank near empty and put a little in and then get it tested again at dmv. pic of my engine today http://www.pbase.com/jimkelly/image/82652516 jim Running any emissions control on the exhaust side? Also heard of running a quart of acetone to help with bringing down levels... Never tried, we tune our cars to pass if asked and paid to. Attached image(s) |
messix |
Jul 22 2007, 08:16 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
that air cleaner is to restrictive. not enough media area on the filter.
jimkelly |
Jul 22 2007, 08:31 PM
Lo-Fi Version | Time is now: 27th September 2024 - 09:20 AM |
