SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
so the clutch finally works, got it all back together this afternoon, drive home went without a problem.
i pull in and park the car and come back 10 minutes later, start her up and the alternator light stays on ... (IMG:style_emoticons/default/WTF.gif) rev her up, no change. turn her off and back on, same thing. i checked all the fuses, rotated them, no change. (IMG:style_emoticons/default/headbang.gif) now effin what? alternator on a 3.6 is internal. how do i check on it ??? (IMG:style_emoticons/default/confused24.gif) Andy |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
so the clutch finally works, got it all back together this afternoon, drive home went without a problem. i pull in and park the car and come back 10 minutes later, start her up and the alternator light stays on ... (IMG:style_emoticons/default/WTF.gif) rev her up, no change. turn her off and back on, same thing. i checked all the fuses, rotated them, no change. (IMG:style_emoticons/default/headbang.gif) now effin what? alternator on a 3.6 is internal. how do i check on it ??? (IMG:style_emoticons/default/confused24.gif) Andy Andy, You could start by checking the battery voltage to see if the charging system is exhibiting a problem. |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
this thread may help. the last few postings are the applicable ones.
http://www.dorkiphus.net/porsche/showthread.php?t=7536 sounds like the exact same thing. |
McMark |
Did you reconnect your ground cable? Just a random thought....
I'm inclined to think it has something to do with that new gauge, but I can't say what. |
SirAndy |
sounds like the exact same thing. nope. see, it worked *fine* all the way home. if it was missing an external resistor or diode or whatever, i would have had that problem from the beginning. i never touched the alternator. lights was off during my drive home. it wasn't until i restarted the car, that it stayed on. (IMG:style_emoticons/default/confused24.gif) Andy |
SirAndy |
Did you reconnect your ground cable? Just a random thought.... I'm inclined to think it has something to do with that new gauge, but I can't say what. yes, ground strap attached ... i took the old gauge with me. thank god i didn't hack into the harness, switching them out will be easy ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
McMark |
it worked *fine* all the way home I debated even posting that because I knew you would say that. But I just gots a feeling. When it's all over we'll see who's right and who's not. (IMG:style_emoticons/default/tongue.gif) |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Andy, it looks like you just installed new gauges. Yes? The alternator light MUST work since that circuit is what excites the alternator. So if the alternator light is not making a circuit, or the bulb is burnt out or not hooked up, that is your problem.
Good luck..... |
SirAndy |
So if the alternator light is not making a circuit, or the bulb is burnt out or not hooked up, that is your problem. yes. i know. like i said, the light STAYS on. doesn't go out. meaning, the bulb works ... see, lighty worky ... (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423657.jpg) (IMG:style_emoticons/default/biggrin.gif) Andy |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
You did check your belt(s)?
McMark |
Did you check the battery voltage running and off to see if there is a difference?
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
SirAndy |
You did check your belt(s)? belt(s) are fine ... (IMG:style_emoticons/default/smile.gif) hey, i've got a reputation to uphold ... (IMG:style_emoticons/default/cool_shades.gif) Did you check the battery voltage running and off to see if there is a difference? here are the numbers, across the battery terminals: • 12.61 V - ignition off • 12.38 V - ignition on • 12.06 V - idle • 12.08 V - idle with gauge bulb disconnected, just for the giggles ... clearly, it's *not* charging ... (IMG:style_emoticons/default/sad.gif) Andy |
McMark |
I don't remember, is the stock diode hooked up to anything?
SirAndy |
I don't remember, is the stock diode hooked up to anything? yes, stock diode is hooked up, but it's not for the alternator circuit. it's for the brake circuit. it's used because the brake warning light has multiple functions (parking brake, master cylinder, seatbelt interlock and emergency flasher) ... (IMG:style_emoticons/default/bye1.gif) Andy PS: to clarify, there's a diode in the alternator circuit on early cars, but i have a '74 main harness ... |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Can, or did, you check the voltage regulator?
SirAndy |
Can, or did, you check the voltage regulator? i wouldn't know how, it's all internal ... (IMG:style_emoticons/default/confused24.gif) Andy |
SirAndy |
alright, i need some strong coffee. i'm gonna drive her up to starbucks (about a mile from my house) and see what happens ...
got my AAA card with me ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Dr. Roger |
My internally switched alternator has but one wire connected to it.
It is tickled by low voltage from the thick wire coming from the battery. Does yours use 1 thick wire or are there 2 or more wires? What model and year is your engine? |
SirAndy |
My internally switched alternator has but one wire connected to it. It is tickled by low voltage from the thick wire coming from the battery. Does yours use 1 thick wire or are there 2 or more wires? What model and year is your engine? i'll have to take the shroud off the motor to get a look. there's no easy access to the alternator. '95 993 3.6L motor ... (IMG:style_emoticons/default/smile.gif) Andy PS: leaving for starbucks, be back in a minute ... |
Lo-Fi Version | Time is now: 25th June 2024 - 08:26 PM |
