AvalonFal |
Member ![]() ![]() Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region ![]() |
How much lateral play, if any, should there be in the tranny shift rod after it exits to the rear of the firewall on a '74 2.0L? I can move mine about an inch side to side and it seems somewhat loose. Bushing problem??
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Way too much! I would bet your firewall bushing is no longer there, if I read correctly. Order a new bushing.
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Yep-
iffin you pull that rubber bellows thing off you will find a pin that is suppossed to have a bushing sleeved around it. Yours is probably in pieces inside the boot- like mine was- and it does no good for the transaxle shifting without it. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:18 AM |
