chris914 |
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California ![]() |
My engine is knocking at idle. And it is getting louder with each autocross!
It appears to be coming from cylinder number three. The engine idles and there is no smoke in the exhaust. At higher RPM’s there is a loss of power and it is running rougher. I don’t think it is a carburetor or ignition problem. Is it cylinder or bearing knock? Is it time to rebuild? Hmmm? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Is it time to rebuild? sounds like it (pun intended) (IMG:style_emoticons/default/biggrin.gif) i say drop the motor and take off the heads and inspect them first. might just be a valve seat trying to work itself out. #3 is notorious for that as it runs the hottest ... (IMG:style_emoticons/default/bye1.gif) Andy |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
I'll give you three choices....
Valve seat, Piston slap, or a rod getting ready to break. Of the three, the piston slap is not as catastrophic as the other two. Feeling lucky? Ken |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Broken rings...
rhcb914 |
member ![]() ![]() Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 ![]() |
Try adjusting the valves and make sure you pull out the valve adjuster screws and look at them closely. About a year ago mine started making a knocking noise that I though was in the bottom end but turned out to be a worn down valve adjuster screw. It was brand new too but had worn flat. I guess that one didn't get the proper hardening or something. Swapped it out, did an oil change and it's been great since.
-Rob |
Lo-Fi Version | Time is now: 20th June 2024 - 11:33 PM |
