Need Help With Removal of Chrome Trim |
Chuck |
Aug 8 2007, 11:58 AM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
I am attempting to remove the chrome trim on the targa bar and sail panels as well as around the windshield on my '73 without damaging it. The sail panel trim has one small screw in the top of it. I've removed that but the trim doesn't seem to want to give at all. What is the secret for removing all of this stuff without bending it or damaging it? Thanks.
Allan |
Aug 8 2007, 12:02 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
There is a nut up in the fender well at the rear of the trim. The ones that run along the side have little expansion clips that hold them in place. The long one across the top just pulls off.
skline |
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
There is an 8mm bolt up inside the wheel well holding it in.
xperu |
Aug 8 2007, 12:13 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I just removed mine, I really don't know if it's the best way, but i removed the screw at the to pf the sail trim, turned the trim counterclockwise about half way turn, then push from the bottom flat wide end. It has a glob of some kind of seal material on the flat shaped fastener holding the sail trim. You just have to be careful when pushing on the trim(be patient) not to bind the trim piece, I had to wiggle it back and fourth several times. Put tape down around the area to prevent scratching the paint. I'm sure there is another way, but worked for me on both my cars.
xperu |
Aug 8 2007, 12:16 PM
I just removed mine, I really don't know if it's the best way, but i removed the screw at the to pf the sail trim, turned the trim counterclockwise about half way turn, then push from the bottom flat wide end. It has a glob of some kind of seal material on the flat shaped fastener holding the sail trim. You just have to be careful when pushing on the trim(be patient) not to bind the trim piece, I had to wiggle it back and fourth several times. Put tape down around the area to prevent scratching the paint. I'm sure there is another way, but worked for me on both my cars. See I told you there was another way! |
Chuck |
Aug 8 2007, 12:59 PM
Thanks guys. That is why this site is the best!
Lo-Fi Version | Time is now: 23rd June 2024 - 12:46 PM |
