computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
I picked-up a set of Weber 40 IDF carbs. I'm looking for the manifolds, air cleaners and linkage to get it all connected. Or where would buy these?
I currently have a set of Weber 34 ICTs running and connected. Can this linkage be reused/adapted? The 40 IDFs that I just bought are freshly rebuilt with a Weber update kit from CB performance using this kit: Weber IDF Update Kit $134 This is what the PO had to say in the ad that I bought these Weber 40s in: "Although they come with all the original jets, venturis, chokes, etc, an update kit from CB performance has been installed on both, opening up the throat to 44mm. The carbs have been re-jetted accordingly. A 12% power gain can be expected over a standard pair of 40IDF's, so if it's more power you want, these will do the trick." --What do think...snake oil commerical or hopeful thinking! Am I crazy to put these on a stock (as far as I know 1.8)? Thanks, Mark Attached image(s) ![]() ![]() |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
CB performance.
Or Jake has a bell crank setup that is also very kewl. Clayton |
computers4kids |
CB performance. Or Jake has a bell crank setup that is also very kewl. Clayton Thanks Clayton, So this one is an OK setup for our cars? Attached image(s) ![]() |
Twystd1 |
YUP... Dats da one.
Clayton |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Aircooled.net fixed me up GREAT with linkage, manifold, filters, and velocity stacks too.
Twystd1 |
Good call Scott. I like John at aircooled.net. Thats another GREAT place to buy our stuff. I would rather give my bucks to John than CB.....
Clayton |
SGB |
Yessir. Thats the ticket. Those manifolds make a big difference in low end torque. You need the velocity stacks too.
SGB |
When you install it, you will need to "supplement" the carb lever to hex bar attachment. I drilled and tapped the bar and used a bigger bolt in there instead of the supplied hex screw. They WILL fail there, when you don't want it (like for me during a DE). It isn't catestrophic, but the balance goes all bad. After you tighten up, the hex screw digs into the aluminum cross bar until it digs a little deeper and goes loose again, then....
addwestern |
NorCal Parts guy ![]() ![]() Group: Members Posts: 314 Joined: 21-June 06 From: Sacramento Member No.: 6,276 ![]() |
Mark-
We have them too and can fix you up. Nate (Clayton go ahead and start now... (IMG:style_emoticons/default/happy11.gif)) |
computers4kids |
Do all these kits work well on jackstands or on wheels? (IMG:style_emoticons/default/av-943.gif)
addwestern |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
plan on fabbing up a throttle cable holding bracket with the cb linkage. mr cox has the lowdown on that one. (IMG:style_emoticons/default/wink.gif)
k |
rhodyguy |
interesting bold text. a 12% power gain by bolting those on. too funny. if they are TRUE 44mm venturis, they'll be real shitty down low. untuneable. phooeey!!
k |
Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
I picked-up a set of Weber 40 IDF carbs. I'm looking for the manifolds, air cleaners and linkage to get it all connected. Or where would buy these? I currently have a set of Weber 34 ICTs running and connected. Can this linkage be reused/adapted? The 40 IDFs that I just bought are freshly rebuilt with a Weber update kit from CB performance using this kit: Weber IDF Update Kit $134 This is what the PO had to say in the ad that I bought these Weber 40s in: "Although they come with all the original jets, venturis, chokes, etc, an update kit from CB performance has been installed on both, opening up the throat to 44mm. The carbs have been re-jetted accordingly. A 12% power gain can be expected over a standard pair of 40IDF's, so if it's more power you want, these will do the trick." --What do think...snake oil commerical or hopeful thinking! Am I crazy to put these on a stock (as far as I know 1.8)? Thanks, Mark I'd go through those carbs very carefully and see what the PO did to them! I don't know how you put a 44mm "throat" in to a 40 mm carb! I'd go back to the stock 28mm venturi and stock jetting...ran good on my stock 1.8. |
addwestern |
I agree Mark. I assume you're just going to use it as a driver right? They probably put a 34mm venturi in it. They may have put larger air correctors in as well.
Lo-Fi Version | Time is now: 25th June 2024 - 12:01 AM |
