mdwman |
Member ![]() ![]() Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 ![]() |
I saw a product designed to wrap around the battery to provide protection from battery acid and to reflect heat. The description said it reflected 90% of radiant heat. Has there ever been a product like this designed for use on the fuel pump? Seems like this would be easier than moving the pump to the front trunk as a remedy for vapor lock on the early models.
toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
It might work, sounds llike a good idea.
You could fab. one, it wouldn't be too hard. Moving the pump to the trunk is not big deal. The biggest benefit is installing the steel lines in the tunnel |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Heat barrier? For where the fuel pump is mounted up front? Not really needed...
Lo-Fi Version | Time is now: 26th June 2024 - 07:11 AM |
