bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Where is the best place to get power from for the carb fuel pump. No more fuel injection stuff. PO had run a hot wire and a switch from the battery and I do not like that setup. All help appreciated. Thanks
911quest |
Member ![]() ![]() Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States ![]() |
Where is the best place to get power from for the carb fuel pump. No more fuel injection stuff. PO had run a hot wire and a switch from the battery and I do not like that setup. All help appreciated. Thanks You mount it using tha factory wires and make a jumper across the the rleay board side of the fuel injection connector and it will run with the key on ( normally) |
bdstone914 |
Exactly which two points need to be jumped? I know which wires go to the fuel pump just not which point to jump with the + terminal to get power.
bdstone914 |
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php solved my problem
purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
and when you get that sorted out... cousin brucey here makes some awesome rebuilt pedal sets!
hehe, pluggin your work bruce |
Lo-Fi Version | Time is now: 26th June 2024 - 07:20 AM |
