rtalich |
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None ![]() |
Installing some Jenvey TB's and have run into a bit of a problem. The linkage rods are too short. It never reaches full throttle with rods adjusted at full length. I have a few ideas as to what to try, but wanted to see if anyone else has had this problem and what was done to fix it.
Thanks, Rob |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Redrill the little arms on the carbs to shorten the throw.
Both Jake and I have used a center pull linkage. |
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
This thread might give you some ideas- they are TWM's, from back when Jake was selling them.
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= David Parsons |
rtalich |
Redrill the little arms on the carbs to shorten the throw. Both Jake and I have used a center pull linkage. Yeah, I'm either going to do that or make a plate that will mount on top of the bellcrank so that I can move the ball joint further from the center. Thanks Dave for that post. I came across that post before I even started my install and it has helped me quite a bit!! BTW - I was able to get a pulley from Brad. Thanks again!! -Rob |
Lo-Fi Version | Time is now: 26th June 2024 - 07:34 AM |
