tango-52 |
Member ![]() ![]() Group: Members Posts: 149 Joined: 18-October 07 From: San Diego County Member No.: 8,243 Region Association: Southern California ![]() |
I put a pair of these in my '73 using the adapter brackets because I didn't want to cut on the floor. The seat itself has four fiberglass feet that extend down about an inch and the mounting bolts are long. Can I grind off the feet and use shorter bolts? Any suggestions are appreciated.
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
A lot of seats don't fit in the 914. Most people using a seat like that use the Corbeau Forza. It fits, but its not as nice as the seat you have. You should ask Corbeau about grinding the feet. You may have no choice but to floor mount those.
tango-52 |
I just got off the phone with Corbeau and was told I could grind off the feet, and if I need to I can even just drill new holes through the bottom as long as I reinforce the holes with large diameter bumper washers. Sounds like I have a project for Friday. I'll let you know how it works out.
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
Please post some pictures when you get them installed. Are you retaining the backpad?
tango-52 |
I will take pictures and I intend on retaining the stock backpad.
jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
tango-52 |
It's done! And it worked out real well. Now I have to put all the pictures in a useable format.
Lo-Fi Version | Time is now: 20th June 2024 - 11:18 PM |
