Fixing the rocker covers, Saving them from cancer |
DNHunt |
Dec 14 2007, 10:09 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Here's what I started with. Rust in the area under the opening for the jack plate.
Because there are some compound curves I decided to fill a small amount with welding and cut the rusty metal from the flatter area. |
DNHunt |
Dec 14 2007, 10:13 PM
I cut out the bad metal.
Then I bent and hammered a replacement piece. I just tacked it tonight and I'll finish welding and grinding tomorrow. Dave |
McMark |
Dec 14 2007, 11:17 PM
DNHunt |
Dec 15 2007, 09:12 AM
Finished 1 side, at least it's ready for primer and filler.
Inside Dave |
Gint |
Dec 15 2007, 09:34 AM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
You're getting pretty good at that Dave.
DNHunt |
Dec 15 2007, 11:10 AM
Here's how I did it. I used a vice, a piece of 2X4 with 1 edge radiused to the curve at the bottom edge of the rocker cover, a piece of 1" galvanized pipe a ball peen hammer, my wire feed welder ad a grinder.
First I filled in a small area that was pitted. I didn't want to deal with compound curves if possible. I ground that down. I then started making the repair piece. First I bent the bottom edge using the vice hammer and wooden block. |
DNHunt |
Dec 15 2007, 11:15 AM
Then I measured from the center of that bend on the rocker cover to the bead on the edge. I transferred that to the ptch and bent that edge over the vice with the hammer.
Then I transferred the curve for the corner onto the patch by tracing it with a pencil. I added enough for the stengthening bead. |
DNHunt |
Dec 15 2007, 11:22 AM
I cut the patch to length and added the mounting hole.
I cut out the area for the curves then used the galvanized pie and the hammer to shape the patch. This is the inner radius. And the outer radius |
DNHunt |
Dec 15 2007, 11:24 AM
This is what you end up with to be welded in.
Dave |
rhodyguy |
Dec 16 2007, 11:06 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
nice work dave.
DNHunt |
Dec 16 2007, 09:43 PM
Homemade paint booth in an unused greenhouse
Plenty of ventilation with the fans Here's the primer sprayed on |
Lo-Fi Version | Time is now: 26th June 2024 - 03:13 PM |
