Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Not much cooling going on between those cylinders. Intake & exhaust on the top?
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Actually thats the bottom..
Lycoming engines use updraft carbs under the engine. Those heads are designed for steady state running at altitude, so their characteristics don't include acceleration properties. |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Jake,
What is there about these steel cylinders that keeps them from having "Acceleration properties".? What would prohibit their use in an automotive application? Clayton |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
What is there about these steel cylinders that keeps them from having "Acceleration properties".? Jake was talking about the heads specifically. Port design and valve size would likely to be tailored to provide specific advantages at a particular cruising RPM. An engine designed for specific applications would not likely do well in another specific application. Just compare 1/4 mile engines with sprint car engines with endurance car engines. |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Aircraft engines run at mostly continuous rpm. On a piston engine you usually set the throttle and lock it in a position. Yes, you do vary it from time to time, but nothing like working that gas in a car. I think the volume and airspeed of air into an aircraft engine are much higher.
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
volume may be high, density will be low. As altitude increases, air pressure decreases.
Type 4 Unleashed |
Lo-Fi Version | Time is now: 25th June 2024 - 08:59 PM |
