Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Definate for Dallas.
If I can find a co-driver I will go to Valdosta. (no chumps please). (IMG:style_emoticons/default/driving.gif) |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I thought you wuz goin' off to be a track heero.....no time fer that low rent AX stuff....or you goin' slummin'?
Joe Ricard |
AXing ain't slumming that's for damn sure.
Actually road course stuff around here is a bit low rent. I still don't know if I will run wheel to wheel anyway. Lapping and What the ricers call Time attack. |
J P Stein |
Well,OK........we'll be going to the Packwood NT next season. Run in XP rather than E Mod.....a bigger class.....there be big dogs there. This winter's mods should more than make up for the 50ish lbs of ballast we needed to add.
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Well,OK........we'll be going to the Packwood NT next season. Run in XP rather than E Mod.....a bigger class.....there be big dogs there. This winter's mods should more than make up for the 50ish lbs of ballast we needed to add. Long drive, but I'm going to be running up at Packwood in "222". Having a beer with JP and Britain is part of the deal. |
J P Stein |
Well,OK........we'll be going to the Packwood NT next season. Run in XP rather than E Mod.....a bigger class.....there be big dogs there. This winter's mods should more than make up for the 50ish lbs of ballast we needed to add. Long drive, but I'm going to be running up at Packwood in "222". Having a beer with JP and Britain is part of the deal. I'm fer it, I'll even buy. I ain't much of a drinker but will make an exception in this case.....maybe even have 2. (IMG:style_emoticons/default/biggrin.gif) |
Randal |
Well,OK........we'll be going to the Packwood NT next season. Run in XP rather than E Mod.....a bigger class.....there be big dogs there. This winter's mods should more than make up for the 50ish lbs of ballast we needed to add. Long drive, but I'm going to be running up at Packwood in "222". Having a beer with JP and Britain is part of the deal. I'm fer it, I'll even buy. I ain't much of a drinker but will make an exception in this case.....maybe even have 2. (IMG:style_emoticons/default/biggrin.gif) Can't wait. |
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
I may sneak up to visit my dad in Grants Pass, Or later this year. Where is Packwood?
This post has been edited by grantsfo: Feb 23 2008, 12:22 AM |
J P Stein |
Your Pass (IMG:style_emoticons/default/biggrin.gif) to Packwood is a fair piece of driving.
North on I-5 to exit 68 in Washington, then 63 miles East. Grant's Pass is about 290 miles from the WA border, IIRC. |
grantsfo |
Your Pass (IMG:style_emoticons/default/biggrin.gif) to Packwood is a fair piece of driving. North on I-5 to exit 68 in Washington, then 63 miles East. Grant's Pass is about 290 miles from the WA border, IIRC. Dang thats over 800 miles one way. I probably stick to events within 400 miles. |
J P Stein |
Aye, matey, 800 or beter.
We're down to 2 NT events on the West Coast now that Atwater is dead with SD being the other. It is a 2 day event, but only 6 runs against the best of the West. A lot of NorCal guys came up last year and I wouldn't be surprised to see more this year. |
Joe Ricard |
I still have plans to go to Dallas this year. Pretty far for me also.
Soon as I figure out what class I will be in ???? the new proposed changes are wierd. Prepared going to be if approved like Mod class with driver. and the min weight is raised 200 pounds. Sucks for me I only go 160 with my helmet. |
J P Stein |
the new proposed changes are wierd. Prepared going to be if approved like Mod class with driver. and the min weight is raised 200 pounds. Sucks for me I only go 160 with my helmet. Humm.....I almost understand what you're trying to write....being North of the Mason-Dickson line makes it hard. |
J P Stein |
the new proposed changes are wierd. Prepared going to be if approved like Mod class with driver. and the min weight is raised 200 pounds. Sucks for me I only go 160 with my helmet. Humm.....I almost understand what you're trying to write....being North of the Mason-Dickson line makes it hard. OK, so I fingered it out myself. They want to raise the minimum weight of all Prepared classes 200 lbs but now include the driver of the car in the total. This would cause me to ballast up another 30 lbs. If this goes thru, I'll prolly pitch the ballast & go to E Mod. I emailed the SEB with blurb against it & raised some hell on the SCCA forums...for all the good it will do. |
Randal |
Yup take the Colin Chapman approach. It just seems crazy to be adding weight back in. |
J P Stein |
Yup take the Colin Chapman approach. It just seems crazy to be adding weight back in. I agree, but I'm 175ish pounds over weight for E Mod and have run out of spots to whittle on...a reassessment is in order, me thinks. Maybe an acid dip of the whole chassis....... (IMG:style_emoticons/default/idea.gif) |
Joe Ricard |
Seen your Hell raising on SCCA forums and had to raise you one.
If it wasn't for the addrenaline rush of Autocross I would have hung it up long ago. But now I am just going to find a place for it and continue to be a back marker. I know I can't compete with the top XP cars nor the top SM2 cars. If I wanted to win I would build an A mod car and bet on the fact that I am faster than the rest of the old guys driving them. |
charlesmac |
Member ![]() ![]() Group: Members Posts: 210 Joined: 27-June 04 From: Richland, MS Member No.: 2,264 ![]() |
Hey Joe, when's Valdosta?
Joe Ricard |
charlesmac |
Yea I think I can do that......wait, what??? (IMG:style_emoticons/default/dry.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 10:40 PM |
