Enigma |
Newbie ![]() Group: Members Posts: 34 Joined: 4-November 07 From: Ontario Canada Member No.: 8,298 ![]() |
Hello,
Im in the process of installing the front oil cooler in my car. The lines run back thru the drivers foot well then down under the left rocker cover. My question is, once you get past the jack post and you want to have the lines turn towards the engine bay, what route do you take with them? Do you just come around the frame or do you cut another hole around the jack post to gain access to the engine bay? Using the heater duct isnt an option. I am using a standard 914-6 oil tank A pix would help out. Cheers |
degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
What kind of lines are you using? I've often used blue soft lines and then either simply wrap under the long, go straight back and use fittings to make a 90 to the thermostat......you ARE using a thermostat right?
I have also gone thru the cockpit and then the fire wall.... |
Enigma |
Here are the picts of mine the return(from engine to tank) runs under the long and there are two bosses must drill out) in the engine bay for the lines out? hope this helps? Great! The last picture gave me the detail I needed! Ill take a peek at my car and see if I can get them thru there. Looks like the perfect solution. Thanks Muchly. To the gent asking about what type of line I am using - stainless AN12. Thanks guys! |
Enigma |
What kind of lines are you using? I've often used blue soft lines and then either simply wrap under the long, go straight back and use fittings to make a 90 to the thermostat......you ARE using a thermostat right? I have also gone thru the cockpit and then the fire wall.... Yes the thermostat is located in the front truck next to the cooler. I use the same setup that Jim Patrick uses. However I removed the engine oil cooler and replaced it with the 993 oil filter console. So the gravity line runs outta the bottom of the orignal tank. the output of the motor runs to the cooler in the front and then returns to the tank. I had them runnning under the long, but it just looks wrong. Im kinda fussy that way. the right way or no way. (IMG:style_emoticons/default/smile.gif) Cheers |
Enigma |
Here are the picts of mine the return(from engine to tank) runs under the long and there are two bosses must drill out) in the engine bay for the lines out? hope this helps? Ok I took a stab at this today. What I found was passing the lines into the fender well in front of the original oil tank I ran into a problem. I found the once they pass thru they must turn a sharp angle downwards. The radius was so small I fear they will KINK when it gets hot. How did you get around this? Did you put 90 deg fittings in the fender well? cheers |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
This is the way it was run in 914-6 #41 for 15 years. It is going back in the same way.
I hope this helps. Bob Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:00 PM |
