McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Here's some pictures of the progress I made tonight. Very labor intensive but hopefully it'll look nice when it's done.
(IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2278.jpg) (IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2279.jpg) (IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2283.jpg) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
mothers?
McMark |
The case was bead blasted which left a rough surface. What I have to do is sand with 400 grit sandpaper, then polish with a rubbing compound and then a polishing compound. I am using a die grinder with felt cones for the rubbing and polishing compounds, but the sandpaper is all manual. I'm not that happy with the bead blasting of the case, but it's the only way to get rid of the oil stains.
Aaron Cox |
kind of anal dont you think? (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/laugh.gif)
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I got lazy doing that to my wheels, so I just etched them again.. (IMG:style_emoticons/default/smile.gif)
Just giving you a way out.. M |
914ghost |
BOB ![]() ![]() Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 ![]() |
I've used a drill w/ a couple different wire brushes before, you can get a little shine that way, and it actually leaves decent base for poishing-eliminates the raw fingers. Try using ...Eagle1 (I think) Mag wheel stripper stuff too instead of sandblasting, it etches the top layer of metal, removes whatever stains and coatings are on it. Just dont spray it on your wheels thinking it will 'clean' them- because it WILL- in a big way.
Luckily on a 914 you only have to polish the top of the case there. R O |
hargray2 |
fuh-q ![]() ![]() Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 ![]() |
Post pics of the end result when you're done say, mid August maybe? (IMG:style_emoticons/default/lol2.gif)
No seriously, that's gonna look great. You're surely not as lazy as I. |
McMark |
ghost, I'll check out the Mag Wheel Stripper. Sounds like good stuff. I'm not sure how far I'm going to go. I have a month or two before the internals come back from Jake, so I've got lots of time to kill. (IMG:style_emoticons/default/smile.gif)
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
QUOTE(acox914 @ Jan 9 2004, 10:19 PM) kind of anal dont you think? (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/laugh.gif) Hey, I polished the top of my case when I had it apart, I just wanted to clean it up a little. The end result is not quite what I expected and it was a lot of work, but it looks better than it did. |
skline |
Pictures?
Attached image(s) ![]() |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Mark, you're going to at that job for a long time.
Tip for ya. After bead blasting, it's easier to start with a rougher grade paper. I used 80, then 200, then 400. And for wheels I went on to 1000. IIWY, I would start your sanding with 80 or 120. It will make the job a little easier. |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
I fear this. My subie engine has some crust on it (from the boat crossing I assume) and I fear trying to clean it up any will result in months of polishing like McMark is doing.
What's the best way to remove casting marks from aluminum? Dremel? |
Rich Bontempi |
914 Road Racer ![]() ![]() Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California ![]() |
You could polish the case inside, it actually will be good for oil flow or quicker oil return to the bottom of the case depending on where you polish!!
redshift |
QUOTE(jonwatts @ Jan 10 2004, 02:59 AM) What's the best way to remove casting marks from aluminum? Dremel? On outside curves, a nice hard-cut mill file. You have to get a rat tail for the inside curves, and you get real pissed off about 10 hours into it. M |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you have bead blasted that case you better pull (and tap) your oil galley plugs.
I absolutely guaranty that you still have glass beads in your oil galleys, no matter how well you have cleaned the case. |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
what are you gonna do to the case to keep it shiny after it's done?
mikester |
Member ![]() ![]() Group: Members Posts: 326 Joined: 18-June 03 From: CA Member No.: 837 ![]() |
I wonder how it will affect cooling.
McMark |
Mark H. - They're already out. (IMG:style_emoticons/default/biggrin.gif)
Sean - I was thinking about anodizing. |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
You guys belong on a 911 list (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 10:56 PM |
