nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
hi all, i'm adjusting the valves
the pelican article says that the retaining nuts are 13mm -- mine are 14 (and tight as hell, i can't budge them)... is this common, or has a PO done some crazy stuff on me? |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I keep the valves right on 6 different cars locally. The 1.7 have been 13 mm. the 2.0's are 14mm. All are 73 and later cars
nebreitling |
great, thanks.
any tips on loosening them up, without stripping them? i just had a 14mm socket do a number on one of those nuts... n |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Use a box wrench.
Also, be sure that the cylinder you are adjusting is at TDC, or the valves will be too tight to adjust. Jeff |
TheCabinetmaker |
try a long 6 point box end wrench. I never use a socket. might be better to remove the rocker arms, and loosen the adjuster nuts on a bench.
nebreitling |
QUOTE(bowlsby @ Jan 10 2004, 05:30 PM) Also, be sure that the cylinder you are adjusting is at TDC, or the valves will be too tight to adjust. maybe i'm a TDC #3 then; because there is NO gap that i can discern between the adjusting screw and the valve. the rockers are tight at #1! BUT, the impeller marks (which i found and remarked -- there was confusion in a previous post of mine) show TDC. i DID recently re-index the distributor drive shaft (long story) -- can that be 180 degrees off and still show TDC on the impeller? |
TheCabinetmaker |
Is there an indexing mark on the top of the dizzy body? it's a small notch. the rotor should be pointing to this area if your on #1 if your not 180 off. Regradless, the rotor should point towards the # 1 wire on the cap.
Lo-Fi Version | Time is now: 25th June 2024 - 11:11 PM |
