914Dan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,833 Joined: 20-February 08 From: Saratoga, NY Member No.: 8,730 Region Association: None ![]() |
The horn on my 914 came on and won't go off. I yanked the fuse so as not to annoy the neighbors, but it's stuck. I pulled the ring off and the rubber donut underneath is dry and all squished up. There is a wire coming up the column and grounded to a tab, that tab is broken off.
Does anyone sell a horn rebuild kit? I looked the the FAQ section but didn't see anything. Thanx, Dan |
pin31 |
Member ![]() ![]() Group: Members Posts: 398 Joined: 30-January 07 From: Newport, Rhode Island Member No.: 7,492 Region Association: North East States ![]() |
Check AutoAtlanta...pdf catalog in "members stuff for sale" section.
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
If you have the new AutoAtlanta catalog, check page 57. I recently rebuild my steering wheel and included the following parts for the horn:
Horn Boot: G901 347 823 01 $12.71 Horn Contact Plate: G914 347 099 00 $39.54 ($15.00 Used) Horn Base Plate: B914 613 805 A $29.50 Good luck! |
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
For competition sake.. I believe Pelicanparts sells them too
914Dan |
Thanks guys. If I remember correctly, when I wiggled the wire without touching anything with the exposed wire, the horn went on. This tells me there's some bad Juju down inside the column.
I'll order the catalogs. Thanx, Dan |
Lo-Fi Version | Time is now: 26th June 2024 - 01:18 AM |
