Need help: rear trunk shocks installation |
JimSar |
Mar 20 2008, 01:49 AM
Fill 'er up Group: Members Posts: 64 Joined: 28-July 06 From: Vallejo, CA Member No.: 6,527 Region Association: Northern California |
A few months ago I bought a "Porsche 914 Gas Shock Kit" on eBay from this vendor:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...178155&rd=1 I've misplaced the instruction sheet, and repeated emails to the vendor over a span of a couple of weeks didn't generate any response. All I really need are the measurements, say from the taillight lens to the 1st hole, and on the lid side, from the front edge to the 1st hole. Any help will be greatly appreciated. Jim |
TINCAN914 |
Mar 20 2008, 05:55 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I bought these as well.
Not to bash, but return them if possible, or cut your losses and contact Craig at CAMP914. IMO they are much easier to mount and after you open and close your trunk lid over time, I believe the screws hold up better at the mounting points with craigs. Just my .02, good luck. |
dr914@autoatlanta.com |
Mar 20 2008, 07:15 AM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I second. Don't do it! And by the way the rear trunk spring rods work perfectly. The rear shocks restrict movement and utility (like swinging the top into the trunk) Don't do it!!!!!!!!!!!!
SLITS |
Mar 20 2008, 11:15 AM
3 cars I've installed these on ... never a problem ... one 3 years ago .... Now I don't worry about torn from the body hinge brackets or replacement of those stupid rollers and the potential blood. I can put my targa top in the trunk with no problems and with the same effort it took when it had torsion bars. If you're a CW more power to you ... keep dealin' with those idiot torsion springs. With his kit you don't have to cut the seal.
Worried about screws .... spot weld the brackets. Jeeeeeeezzzzzz (IMG:http://i239.photobucket.com/albums/ff312/professor914/g.jpg) (IMG:http://i239.photobucket.com/albums/ff312/professor914/g1.jpg) (IMG:http://i239.photobucket.com/albums/ff312/professor914/g2.jpg) (IMG:http://i239.photobucket.com/albums/ff312/professor914/g3.jpg) (IMG:http://i239.photobucket.com/albums/ff312/professor914/g4.jpg) |
blitZ |
Mar 20 2008, 11:23 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I have an internal cable release for my rear trunk. Do these struts pop the trunk lid up, when the latch is released?
Rand |
Mar 20 2008, 11:31 AM
I took some shocks off a hatchback at a pull-a-part wrecking yard and fabbed & welded my own brackets. Cost me $5 in parts. Works perfect, still easy to get the top in and out. Glad to have that stock torsion spring outta there.
I mounted the lid/top ends first, propped the trunk up fully open, that told me where to attach the other ends of the shocks. Simple, no instructions or measuring needed. Mine does not lift the lid as soon as the latch is released... It pops enough to get under it, then I lift the lid a few inches, then the shocks lift and hold from there. |
SirAndy |
Mar 20 2008, 11:35 AM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have an internal cable release for my rear trunk. Do these struts pop the trunk lid up, when the latch is released? nope ... there's no pressure on the lid with the struts all the way down ... however, on my car, just the pressure from the rubber trunk gasket is enough to make the lid come up 1/4" or so when you press the lock ... i also have the gas shocks in the front trunk and i added a small spring next to the lock which will pop up the lid just enough when released ... and i second welding in the brakets. much cleaner and no leaks around the screws/rivets! (IMG:style_emoticons/default/bye1.gif) Andy |
SLITS |
Mar 20 2008, 11:41 AM
The spring on your rear trunk latch will "pop" the trunk up enough to get your fingers under the lid. You then just start to raise it and the gas shocks will take over with a nice smooth motion ... not a chin busting fly up like the torsion springs.**
** Ok, so I exaggerate a bit. |
Kargeek |
Mar 20 2008, 11:46 AM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
I made my own using 944 rear hatch shocks. Welded my own bracket and attached the front hinge pin to the trunk hinge bracket. I had to notch the rear bulkhead to clear the shock rod. Not factory but hey, I at least used porsche parts. No problems with the top fitting and removing the torsion bars cleaned up the engine compartment and gave room for my rear facing carb throttle linkage. Attached image(s) |
Rand |
Mar 20 2008, 11:49 AM
Nice. I mounted my top ends the same way to the hinge bracket.
JimSar |
Mar 21 2008, 12:33 AM
Thanks, everyone, for your help/opinion. SLITS, special thanks for taking the time to post pics of the directions.
Jim |
blitZ |
Mar 21 2008, 05:23 AM
Kargeek
I was looking at your rear shock support. Where did you get it and does it help? |
Bartlett 914 |
Mar 21 2008, 06:01 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I made my own using 944 rear hatch shocks. Welded my own bracket and attached the front hinge pin to the trunk hinge bracket. I had to notch the rear bulkhead to clear the shock rod. Not factory but hey, I at least used porsche parts. No problems with the top fitting and removing the torsion bars cleaned up the engine compartment and gave room for my rear facing carb throttle linkage. Your installation looks really clean. What shocks did you use? |
MoveQik |
Mar 21 2008, 08:49 AM
What size wheels can I fit? Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I just got a set of these shocks that were donated to the Route 66 run by ??(sorry I can't remember) The directions called for cutting the front of the trunk (IMG:style_emoticons/default/blink.gif) . I couldn't bring myself to doing it so I mounted them in a way that avoided any cutting. They work perfect, top fits in...did I mention no cutting? (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
MoveQik |
Mar 21 2008, 08:56 AM
Decklid
Attached image(s) |
MoveQik |
Mar 21 2008, 08:59 AM
Trunk still intact (IMG:style_emoticons/default/biggrin.gif) The mounting brackets are reversed relative to which goes on the car vs decklid when compared to the "proper" way the instructions called for. But like I said, I couldn't see cutting the trunk for these things. It is never good when the instructions list a hacksaw as required tool for installation.
They do work perfectly installed this way. I wouldn't do it on a FG lid but stock lid is plenty strong. Attached image(s) |
SLITS |
Mar 21 2008, 09:25 AM
Smooth move Slick .... I believe those are Boxtsers kits that "require" cutting. The other kit sold on eBay doesn't which is much preferable.
ericread |
Mar 21 2008, 10:23 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
How about the kit that is sold on CAMP914? Does anybody know how that kit installs.
MoveQik |
Mar 21 2008, 01:56 PM
Smooth move Slick .... Wellll Ron, you know me. I'm quite the wizard when it comes to fabricating and such. (IMG:style_emoticons/default/blink.gif) |
SLITS |
Mar 21 2008, 02:50 PM
Lo-Fi Version | Time is now: 27th September 2024 - 12:55 PM |
