Euro Spec Dish Volume, Mahle 2.0L |
solex |
Apr 5 2008, 09:01 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Anyone know that dish volume for a Mahle Euro spec piston?
Thanks, Dan |
Joe Ricard |
Apr 5 2008, 09:42 PM
Measure it. Just like you do the Chamber Volume.
There is a difference in opinion. but this is what I know and have seen there is a near flat top piston that is commonly called Euro there is a slight dish you can see with a straight edge. There is a 3cc dish Mahle Other version of Euro. There is a 6 cc Dish Mahle U.S and then a huge dish Mahle like over 10cc Bus Just measure and calculate your compression ratio. |
solex |
Apr 5 2008, 11:30 PM
Measure it. Just like you do the Chamber Volume. There is a difference in opinion. but this is what I know and have seen there is a near flat top piston that is commonly called Euro there is a slight dish you can see with a straight edge. There is a 3cc dish Mahle Other version of Euro. There is a 6 cc Dish Mahle U.S and then a huge dish Mahle like over 10cc Bus Just measure and calculate your compression ratio. Thanks Joe, I did not measure the volume on the heads but it look like I will need to on the pistons. |
Joe Ricard |
Apr 6 2008, 06:20 PM
Yea you are going to learn a lot about measuring before you are done.
When setting your deck aim for .040 close enough to make power and far enough not to be dangerous and crash things. |
solex |
Apr 6 2008, 07:09 PM
It is actually the last thing to measure, I was hoping that one of the numbers on the piston would tell me the volume but I cannot make sense of it...
solex |
Apr 7 2008, 04:49 PM
I measured the dish it came up to 2.75 - 3.00 cc's.
Calculating the compression ratio I get 8.1: 1 using a total deck height of 0.60 requiring shims of 0.055 on one side If I go to a deck height of 0.65 the compression ratio drops to 8.0:1. Here are my numbers: Bore 94 mm Stroke 71 mm Cylinder chamber volume 56 cc Dish in Euro Piston 2.75 - 3 cc Stock Cam deck height w/o shims 0.005 on one side 0.013 on the other side New cylinders, pistons rebuild heads and rods. Now for the questions: What should I do regarding the shims? I understand that going over 0.60 on a shim is not good, how will this effect my push rods and valve geometry? One other thing one of the rings is stuck in the landing how to I free it without damaging the landing, ring or piston? Thanks, Dan |
solex |
Apr 7 2008, 08:25 PM
I free-ed up the top ring, looks like the ring did not seat correctly and dented the landing surface. Should I attempt to clean it up with a file?
Joe Ricard |
Apr 7 2008, 09:24 PM
just my opinion on your deck of .060.
That's a lot of deck. and you will make more power with a bit tighter. I would be suspect of you measurements if the engine is off that much side to side. Without messing around with mine it came out .005 difference side to side. swapping rods and pistons I managed to get it down to a repeatable .002 side to side well with in specs. |
Jake Raby |
Apr 7 2008, 09:29 PM
Loose deck= loss of efficiency.
3cc dish= Euro Spec piston 7cc dish- US spec piston 13cc= Bus spec 94mm Piston |
RJMII |
Apr 7 2008, 09:51 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Jake Raby |
Apr 7 2008, 10:09 PM
More than .060
orange914 |
Apr 7 2008, 10:24 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
solex |
Apr 8 2008, 02:09 AM
MrKona |
May 3 2008, 12:10 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Loose deck= loss of efficiency. 3cc dish= Euro Spec piston 7cc dish- US spec piston 13cc= Bus spec 94mm Piston When measuring deck height on a Euro spec piston with a 3cc dish, is the deck height measurement from the center of the piston (in the dished part) to the top of the cylinder? Or is it from the flat surface at the perimeter of the piston head to the top of the cylinder? I've been searching threads but can't find this specific information. I want to make sure I do this correctly the first time. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:31 AM |
