'HELP'914 newbie - retrofit of new style fuel pump |
P.Rocket |
Apr 10 2008, 03:53 AM
Member Group: Members Posts: 54 Joined: 17-March 08 From: Abbotsford BC Member No.: 8,822 Region Association: None |
New to the land of 914's. My '74 2.0 fuel pump puked fuel out over the winter. The old style seems like a poor set-up and location (fire hazard?). Also they seem a little rare to find for a reasonable price.
Just curious if anyone one has some information on installing a new style pump upto the fuel tank location. I would like to achieve this and have it look somewhat OEM. So if you have any ideas or location pics for me, that would be a big help. I've been told that the '75 and '76 models ran this set-up and have a cover plate in the front trunk. Thanks for any input you can forward. |
BarberDave |
Apr 10 2008, 04:45 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Auto Atlanta and others have a fuel pump relocation kit available,contains every thing you will need except the fuel pump, ( page 44 ) $55.00 A.A. has rebuilt Fuel pumps also $185.00.( page 43 ) Altho I have run mine since 2000 with it in the stock location with only a problem once. Post here in the Parts F/S and I am sure someone will have a good F. Pump for Sale. (IMG:style_emoticons/default/welcome.png) You came to the right place! Dave (IMG:style_emoticons/default/slap.gif) |
ejm |
Apr 10 2008, 05:19 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Couple of pics of the late fuel pump location
Attached image(s) |
type47 |
Apr 10 2008, 08:10 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
one thing that is can think of about your project of moving the FP up front is the plastic fuel lines that run through the tunnel between the seats. with the FP in the stock (70-74) location, the FP sucks the fuel through the plastic lines thus the lines are under low pressure. if the FP is relocated to the front, the FP pushes fuel through the plastic fuel lines thus the lines are under high pressure. the plastic lines, if original, are >30 yr old so may not hold up under high pressure. moral is: if you're going to relocate FP, install SS fuel lines also. (search this site for stainless steel fuel lines)
P.Rocket |
Apr 10 2008, 08:15 AM
Great info and pics so far guys, thanks for that. Anyone else that has anything to add, much appreciated.
Cheers! (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 06:58 PM |
