orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
i'm looking for the best plug to run. the heads are 2.0 units that have been modified by LH for the smaller plug. they didn't come with any plugs to referance, so i've got no starting point. what do any of you run? whats your heat and gap? i'ts a 2056 with a 9550 cam 8.2:1, d-jet, pertronix ignition and s/s exhaust. it'll be accasion use and driven in the hot central valley area of ca.
mike |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
NGK DPR8EA-9 I also think there's a cross ref without the R (resistor) in the code.
Gap depends on coil, around stock gap with blue coil, bigger with higher discharge systems. |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 963 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I'm running the same engine , mine is about 9+/1 and Jake sent me NGK #DP8EA.
You will love this engine combo, Mine is in a 912E and it pulls very strong. I am running carbs that may change the heat range but I doubt it. Al Jake or Len may want to come in if I gave the wrong plug # |
Mark Henry |
Yep it's the same number with out the "R", if you get radio interference get the ones I said. I’ve tried them both, seat of the pants I couldn’t tell any difference.
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
Same number. These are available at motorcycle dealers, if you can't find them elsewhere.
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Thats the best plug I have found... I use them in most any application and CR with great results.
I do sell them in the store if you can't find them locally. |
orange914 |
thanks all, it's possible i may have the engine/trans ready for install this W.E. if all goes as planned (IMG:style_emoticons/default/smile.gif) ... rarely never does though! (IMG:style_emoticons/default/mad.gif)
mike |
Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
thanks all, it's possible i may have the engine/trans ready for install this W.E. if all goes as planned (IMG:style_emoticons/default/smile.gif) ... rarely never does though! (IMG:style_emoticons/default/mad.gif) mike Mike, You can get those NGK plugs at any NAPA auto parts store (best price I found) if they don't have them in stock, they can order them and you will have them in a day or two. Dominic |
Lo-Fi Version | Time is now: 26th June 2024 - 01:17 AM |
