> 1974 1.8L to 2056 engine build, Start to Finish (this may take a while!)
Rick L
post May 13 2008, 06:19 PM
And...we're off!
The goal: Build a 2056 from a 1.8L jet. We'll use the 1.8 Case and Heads, new 96mm P&C's, Raby Cam & Valvetrain kit, and, for the moment, put an Ljet or Djet back on it. Eventually it'll get dual carbs, but I can't drop the extra G just yet.
I'll include as manay pics as I can. I got a little ahead of the camera with this so the engine is already out of the car, the tranny and exhaust are off and these pics show the rats nest (Ljet, harness, vacuum), throttle body, intake runners and right side tin coming off.
Had to use the cell phone cam for these, future pics will be better.
Rick L
post May 13 2008, 06:22 PM
picsAttached Image
Rick L
post May 13 2008, 06:23 PM
Here's what many years under a tree w/o a rain tray will do for your motor!
SGB
post May 13 2008, 06:24 PM
just visiting
GREAT!
It is really hard to stop and take the pictures when you are making progress AND too filthy to touch the camera (or phone especially) I even put my oldest dig camera in the garage and still don't document all the stuff I do.
Good luck with the engine. Sounds like a good plan. Take your time, and check then recheck everything.
Keep those pictures coming!
crash914
post May 13 2008, 06:38 PM
its a mystery to me
When did you take those?
I guess I got to look in the garage more often.....
sure that you did not take pictures of my motor?
type47
post May 13 2008, 06:43 PM
Viermeister
cool, columbia MD even. even cooler, 74 1.8 even (IMG:style_emoticons/default/biggrin.gif) maybe you can find some parts this weekend at the carlisle import/kit car event.
plymouth37
post May 13 2008, 06:49 PM
God speed! Get to work!
Cevan
post May 14 2008, 01:15 PM
Question: (I keep kicking this idea around all the time because I have a couple of 1.8 motors lying around just begging to be converted to a 2056). If you put carbs on down the road, won't you need to put in a new cam to take advantage of the carbs?
Rick L
post May 14 2008, 05:48 PM
QUOTE(Cevan @ May 14 2008, 03:15 PM) *
The way I understand it, no. Jake says that you cam it the same regardless of FI or Carbs. You just won't get the full HP advantage out of the FI, it acts like a fuel governer. FI = 110-115HP, Carbs = 120-125HP.
Herb, I stopped in for a couple hours on Monday and went to town. You busy Friday? I've got a mid-day meeting but would like to do some more on both our cars.
Have I mentioned that I'm STOKED!! I intend to drive this bad boy to ECC this fall! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif)
Rick L
post May 14 2008, 05:49 PM
QUOTE(plymouth37 @ May 13 2008, 08:49 PM) *
Thanx - By the way, that's a bad ass graphic at the bottom of your frame.
orange914
post May 15 2008, 06:59 PM
http://5starmediaworks.com/index.html
did you go with the 9550 cam? remember NOT to run more than 8.3:1 if you'll be running o.e. injection. thats why you'll limit yourself in h.p. if you dont keep comp. down and run the f.i. you'll probably burn a piston. ask many of the members here.
good luck with the build, and definately have a plan on what carburation your engine will run on the finished project. just be careful not to damage all that expense and effort before the carb install
orthobiz
post May 15 2008, 07:43 PM
I thought the 1.7 and 1.8 could only go to 1.9 liters????
Paul
orange914
post May 15 2008, 07:46 PM
QUOTE(orthobiz @ May 15 2008, 06:43 PM) *
Paul
both can us 96mm p&c's for 1911. the 1.8 heads fit the cylinders but the 1.7 have to be cut
crash914
post May 15 2008, 08:04 PM
its a mystery to me
Rick, I will be home Fri at around 5:00.. I know the wife wants family time, but if you were already here......see ya later...
Gint
post May 15 2008, 09:56 PM
Mike Ginter
Good for you. You do realize that in addition to what you listed in your first post that you also need a 71mm stroke crank and 2.0 rods to make 2056 right? Otherwise, you're creating a 1911.
crash914
post May 16 2008, 04:19 AM
its a mystery to me
Wife is working today, so it is all yours...we can put the motor up on the engine stand to help with the disassembly...
Rick L
post May 16 2008, 09:00 PM
Sorry Herb, got roped into house projects today. The wife discovered I was off today and took the day off too. I'll call you this weekend and re-schedule.
Kenny, thanx for the comp ratio info. I hope to have the carbs by the time I finish the build so I don't have to F with the FI. I am purchasing the 9550 cam.
Gint, I'm on it. I intent to harvest a crank and rods from one of Herb's 2.0 motors.
Have I mentioned Herb rocks?! I really appreciate the time, the garage, the tools......what kind of beer do you like again?
Rick L
post Jul 6 2008, 07:20 PM
Herb and I finally got the case cracked. 30 years of wear and tear were very evident. It was also apparent that the heads had been off as well. Each cylinder had a stack of 4 shims. I never did a leak down test on the motor because I knew I was gonna pull it, but I'll bet you can look at the pics and tell me what the results would have been!
Now it's of to Jake's with the crank, flywheel, clutch, and rods for balancing.
Here's a look at what we found, btw, it was dirty!
Caution: Dirty engine porn!
Rick L
post Jul 6 2008, 08:01 PM
Here are the p&c's:
Attached Image 1&2
Attached Image3&4
Rick L
post Jul 6 2008, 08:08 PM
The shims, spread so you can see all 4.
And the valves:
3Attached Image & 4Attached Image
the 1, 2 head was unremarkable
- Lo-Fi Version Time is now: 15th March 2025 - 03:10 AM
