davesclassicvws |
davesclassicvws ![]() ![]() Group: Members Posts: 82 Joined: 5-October 05 From: Camas,Wa Member No.: 4,917 Region Association: Pacific Northwest ![]() |
Ok, Here's what I want to know. I recently rebuilt a Targa top for 914 which included new seals all the way around. I noticed this squeek before the rebuild but thought the new seals would eliminate this .
As I have thought about this and read more on this forum, here's what I've come up with, the back half of the 914 is essentially held on by the floor, so the stress points are just behind the doors. As the car is going down the road and travels over bumps the body is flexing and this is reverbiated through the targa top, thus the seals are squeeking from the flexing. My question is this: How common is this? Is this an indication of compromised longs? or is this normal with all 914's? Does adding a engman kit eleviate this problem in any way? As far as I can tell the Targa top does not have any capacity to tighten onto the car body. The new seals should be providing as tight a seal as possible. I'm curious if the engman kit will reduse this flex and if its really worth it on a car that's not going to go on the track. I just enoy driving the car around town on the weekends. |
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Might try slipping a piece of rubber tubing over the hooks on the rear latches on the targa bar. This sometimes adds just the little extra bit to cut out some squeeks. Not guaranteeing that it will work, but the price is right to try! (IMG:style_emoticons/default/wink.gif)
davesclassicvws |
Might try slipping a piece of rubber tubing over the hooks on the rear latches on the targa bar. This sometimes adds just the little extra bit to cut out some squeeks. Not guaranteeing that it will work, but the price is right to try! (IMG:style_emoticons/default/wink.gif) I could just leave the top off like in your pictures but it's not very practicle in SW Washington. |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Mine is all rebuilt and has no squeaks at all but then again it's rarely on either.
A couple of suggestions. 1. Use the OEM style rear seal with the felt 2. Coat the seals with a light coat of rubber safe lubricant. I use Sil-Glyde and can be bought at Napa stores. Also put a light coat under the rubber blocks at the latches. I do think the Engman kit reduces some of the flex and associated noise.... |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
the noise does not come from the seals, it comes from the rubber blocks that sit on top of the latch mechanism.
you can take some fine sandpaper to the blocks and rough them up a bit. you can also use graphite lube on them or even glue some felt over them. i also slid a small rubber hose over the "nipple" on the top that the hook on the latch hooks into. that adds a bit more pressure on the top and makes it squeel less ... (IMG:style_emoticons/default/bye1.gif) Andy |
r_towle |
You have a top...damn I feel gyped...my car has no roof...
Rich |
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
the noise does not come from the seals, it comes from the rubber blocks that sit on top of the latch mechanism. you can take some fine sandpaper to the blocks and rough them up a bit. you can also use graphite lube on them or even glue some felt over them. i also slid a small rubber hose over the "nipple" on the top that the hook on the latch hooks into. that adds a bit more pressure on the top and makes it squeel less ... (IMG:style_emoticons/default/bye1.gif) Andy (IMG:style_emoticons/default/agree.gif) Almost exactally what is done on my car. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,115 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
glycerin...again. any rubber contact points. cut 2 little rectangular pieces of adhesive backed felt and place them in the recesses for the rubber blocks on the targa bar. i was into a roadtrip, the top was on and the squeeky racket was driving me crazy. got off the freeway, went to a walgreens bought the felt and a cheap pair of scissors. money well spent.
k |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I agree with Andy and Kevin. Glycerin on the rubber blocks cured mine
r_towle |
Glycerin is sold at any pharmacy in the hand lotion area.
But I still feel gyped...I never have my roof... Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 08:34 PM |
