Wanna9146 |
Member ![]() ![]() Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States ![]() |
Is there a significant difference between 914/4 rear braker calipers and 914/6 calipers? Can they be interchanged?
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
They can be swapped as a pair, but you might change the brake balance.
The 914/6 uses 38mm pistons vs the 914/4 33mm pistons. The 914/6 uses the same size pads as the 914/4 does on the front, but requires the large hole for the large pin. Naturally, the 914/6 rear caliper is larger than the 914/4 variety, but does look similar. 914/4 ![]() 914/6 ![]() note the lack of a rib on the back side of the 914/6 caliper |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE The 914/6 uses 38mm pistons vs the 914/4 33mm pistons. The 914/6 uses the same size pads as the 914/4 does on the front, but requires the large hole for the large pin. Naturally, the 914/6 rear caliper is larger than the 914/4 variety, but does look similar. ...all that and about $1,250.00 (IMG:style_emoticons/default/biggrin.gif) |
davep |
...oh, at least...and providing you can find someone willing to part with them. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:44 PM |
