Heeltoe914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 ![]() |
I have been hearing about the process for a few years now but I am unable to find shops or engine builders that are using it.
The idea as I read it is that it adds strength to the surface and the part itself as well as cutting down friction on bearing, rings, piston, liners cranks or whatever part is treated. up to 25% less friction. Anyone have any input to the quality or the result you have experienced using this: http://www.wpctreatment.com/ or a like process. I am very close to trying it and just cant pull the trigger on some race motor parts without some real world feedback. |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I've used a similar prosess on a bunch of engine and transmission parts. On my 911, I had all the rockers/shafts done, the cams done, the ring and pinion done, 3-5 gearsets done, the sliders, spiders and some of the bearing races done.
I really can say if it has made any difference at all though, I haven't had any problems though either.. I think the gains are small Used Evans Performance |
Smitty911 |
Member ![]() ![]() Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California ![]() |
After watching the video it appears that they are blasting it with a media, which will give you a surface that is dimpled for oil retension and some hardness changes.
This is different from engine coatings like Evans. Looks like sandblasting all your parts might do the same thing, LOL. Smitty |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
if info-mercial products are really as advertised, they will, by popular demand, hit the main stream. products like oxy clean, george foreman grill are now sold everywhere because they do as promised. products like the ron poepeal bald head instant hair spray are not found in mass distribution. (cause I bought it all)
sean_v8_914 |
robo pliers were an info-mercial product till Sears bought the design.
Lo-Fi Version | Time is now: 22nd June 2024 - 08:17 PM |
