> relay box, do I need it
bernbomb914
post Jan 24 2004, 09:42 PM
one of the oldest Farts on this board
we pulled the engine on the yellow beauty and found when we pulled the relay box the bottom had been raped. half the black insulation tar has been removed. it is a 1.8 fi and I am replaceing it with a 2270 with webers. do I need to keep this relay box?
my researdh says it is for the FI but I dont know if it has other functions.
Bernie (IMG:style_emoticons/default/confused24.gif)
Qarl
post Jan 24 2004, 09:45 PM
Shriveled member
It has the voltage regulator, the fuses for the heater fan blower, the rear window defroster (if you have it), and something else...
Aaron Cox
post Jan 24 2004, 09:46 PM
Professional Lawn Dart
im running webers and i kept the box....controls other stuff than FI too
peel all the tar off, and pot it with RTV black silicone.
post Jan 24 2004, 10:01 PM
Resident German
runs the puel pump too ...
bernbomb914
post Jan 24 2004, 10:10 PM
Is there a way to test it to make sure that it is working correctly?
Bernie
Aaron Cox
post Jan 24 2004, 10:18 PM
trial and error? (IMG:style_emoticons/default/laugh.gif) , ask DD, im sure he knows, being the electrical guru
sj914
post Jan 24 2004, 11:50 PM
The relay board is just a board that has contacts like a pcb. Just take a a multimeter and the haynes manual and check for continuity. If your just running webers, you can delete the board and rewire for the fuel pump, heater blower and starter.
McMark
post Jan 25 2004, 12:40 AM
914 Freak!
Don't forget the Tach and coil 12v is in that bunch as well.
Leave it there.
sj914
post Jan 25 2004, 12:46 AM
Okay leave it then. But if your really serious about taking it out, you'll have to run separate wiring for those things. Especially if it uses a relay or fuse.
bernbomb914
post Jan 25 2004, 01:05 AM
Thanks for the info I will clean it up and keep it where it belongs
Bernie
Dave_Darling
post Jan 25 2004, 01:27 PM
914 Idiot
You can indeed get rid of it, but you have to connect all of the wires of the various harnesses that hook up to it to each other correctly. You will also need to mount the voltage regulator correctly and hook it up into the alternator warning light circuit. And mount relays for the heater blower fan (if you have one) and for the fuel pump (strongly recommended).
Easier to keep the board.
--DD
- Lo-Fi Version Time is now: 2nd January 2025 - 08:08 AM
