Eric Taylor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 ![]() |
The fuel pressure regulator has no effect on the pressure. It seams that no matter which way I turn the nut on the regulator there is no effect on the pressure. Did my regulator go bad? Right now it's at 32 LBS which isn't terriable but, I would like to drop it to the propper spec. Any ideas?
Eric |
Air_Cooled_Nut |
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None ![]() |
Sounds broken. If you can screw it in all the way without it affecting fuel pressure then it's ka-pooy. Engine is idling when you adjust, correct?
Eric Taylor |
LOL, it's suppost to be idiling when I adjust it? I was always afraid to do that.
I'll try it. Eric |
Lo-Fi Version | Time is now: 20th June 2024 - 05:44 AM |
