Fuse Box, Question |
Mavrick272 |
Jul 9 2008, 09:45 PM
Newbie Group: Members Posts: 41 Joined: 24-April 08 From: Rockford, MI Member No.: 8,962 Region Association: Upper MidWest |
are all the fuses on the fuse box the 8 amp white ones?
I got this car in "as is" condition and I am not sure if the fuses were replaced correctly... thanks |
jsayre914 |
Jul 9 2008, 09:59 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Fuses and their values are described in the 914 owners manuals. If you are without an owners manual, the following is provided:
If you have a 1970 thru 1973 914, the values are: Position Value Item 1 8 High beam, left 2 8 High beam, right 3 8 Low beam, left 4 8 Low beam, right 5 8 Parking light, left 6 8 Parking light, right 7 8 License plate lights 8 25 Wipers, horn, fan, lighter 9 8 Tail lights 10 8 Fog lights 11 8 Emergency flashers 12 25 Retracting headlights 1974 and later fuse descriptions and sizes are similar, except fuse positions 8, 10, and 12 are 16 amps. The amp ratings are marked on the ceramic body of the fuses themselves. They are color coded as follows: 8 amp - white 16 amp - red 25 amp - blue If you get disoriented as to what end is what on the fuses and positions, you can lower the fuse panel by taking out the two screws that hold it to the underside of the dash. At position 1 there are white wires on the connectors, and at position 12 there are red wires. Jon Lowe - PCA WebSite - 5/24/2002 |
Eric_Ciampa |
Jul 9 2008, 10:00 PM
CHAMP914 Group: Members Posts: 152 Joined: 3-April 03 From: Placerville, CA Member No.: 511 Region Association: Northern California |
Here is the link to the PP site with all the information you need. I have had to print it out more than a few times.
http://www.pelicanparts.com/914/technical_...rical_fuses.htm Edit: jsayre914 beat me to it. |
ericread |
Jul 9 2008, 10:13 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Here's a link to Jeff Bowlsby's rare documents website. There is a 1974 2.0L Owner's Manual third from the top.
http://members.rennlist.com/914_collectibles/RareDocs.htm Jeff's got some amazing stuff, so when you get time check it all out. http://members.rennlist.com/914_collectibles/ Eric Read |
Mavrick272 |
Jul 9 2008, 10:18 PM
awesome
thanks guys! |
Mavrick272 |
Aug 3 2008, 10:15 AM
ok, so what do I do if my fuse panel cover is missing?
Does fuse #1 start on the left side or the right side? (I'm assuming left) |
ejm |
Aug 3 2008, 10:21 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,705 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE Does fuse #1 start on the left side or the right side? (I'm assuming left) Correct..the drivers side...the cover isn't numbered anyway |
Lo-Fi Version | Time is now: 22nd December 2024 - 06:12 AM |
