neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
the strut hole and notch in the a-arm ball joint shaft:
![]() the chamfered pin: ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Does the post of your ball joint have a notch in it for the pin? It looks like you have an older style strut. The hole on the strut should be small on one end and big on the other like the pin.
michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
Hi if there is a sloton the bottom of the strut, you have the old-style strut. That one uses just a screw.
(IMG:style_emoticons/default/smilie_flagge6.gif) |
neo914-6 |
Strut has a hole, the ball joint notch is more V shaped. Here's an older pic of a ball joint with a semi-circle notch vs V notch.
![]() It's 911 Boge with 914 a-arm. Pelican #'s same #'s, pic does not show the notch 911-341-049-01-M69 Ball Joint, 911/911 Turbo (1974-89) 911-341-049-01-M69 Ball Joint, 2 Per Car, 911 (1972-89) ![]() same #'s 901-341-049-00-M69 Ball Joint, 911 (1972-89) has semi-circle notch 901-341-049-00-M69 Ball Joint, 914 1.7 (1970-06/72), 914-6 (1970-06/72) NOTE: use 900-075-111-08-OEM Bolt, Hex-Head M10 x 30, 911 (1965-73) ![]() only 1 # for these, same as mine pictured above 911-341-119-06-M260 Threaded Pin for Ball Joint Attachment, 911 (1972-73) 911-341-119-06-M260 Threaded Pin for Ball Joint Attachment, 911 (1974-89) Elephant sells these decambered BJ's for $350. fits 72-89 and has the V notch... ![]() This tells me the V notch is correct with the pin I have, now to figure why it's not aligning... |
chris914 |
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California ![]() |
To get mine to align I used a jack to lift the arm. To protect the arm place a piece of wood between the two. Be careful not to push up on the heat shield.
neo914-6 |
To get mine to align I used a jack to lift the arm. To protect the arm place a piece of wood between the two. Be careful not to push up on the heat shield. (IMG:style_emoticons/default/idea.gif) You may be on to something, my first pic shows the V notch isn't in the center of the hole likely because the strut bottom corner is hitting the hanging a-arm. Will jack it up and install the pin again... |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,120 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Use a round punch to align hole. It seems like the wedge pin will only go in from the rear if I remember correctly.
neo914-6 |
Use a round punch to align hole. It seems like the wedge pin will only go in from the rear if I remember correctly. That did it, Thanks for all the suggestions everyone! One other problem I had was the hole was smaller than the dia of the pin because of the powdercoating. I had to file it with a rat tail file since I didn't have a drill slightly under 1/2" or a small honing tool. Ideally this should be done before mounting the strut... (IMG:style_emoticons/default/rolleyes.gif) ![]() |
Lo-Fi Version | Time is now: 29th April 2025 - 01:11 PM |
