slugmika |
Member ![]() ![]() Group: Members Posts: 208 Joined: 19-February 03 From: Finland Member No.: 318 ![]() |
I'am looking for a nice 914 around LA.
We are coming to visit SEMA show and will also be spending some time in LA. I really dont want to rent some lame compact, so we really need to find 914 which we can use while in LA. Good solid cars with as little rust as possible (IMG:style_emoticons/default/smile.gif) dont mind the looks, just need to be solid. Price range is 1000-5000$ Main thing is that we can use it while we are in USA and that it is good enough condition to make it worth shipping to Finland. Ideal would be original 2.0 with no cheap make overs, original (even worn) paint, minimum rust, good engine and trans. Mika maad914@hotmail.com |
elswick |
Newbie ![]() Group: Members Posts: 11 Joined: 21-July 08 From: los angeles Member No.: 9,328 Region Association: None ![]() |
I'am looking for a nice 914 around LA. We are coming to visit SEMA show and will also be spending some time in LA. I really dont want to rent some lame compact, so we really need to find 914 which we can use while in LA. Good solid cars with as little rust as possible (IMG:style_emoticons/default/smile.gif) dont mind the looks, just need to be solid. Price range is 1000-5000$ Main thing is that we can use it while we are in USA and that it is good enough condition to make it worth shipping to Finland. Ideal would be original 2.0 with no cheap make overs, original (even worn) paint, minimum rust, good engine and trans. Mika maad914@hotmail.com I might have what you want but it needs smog cert for california. Has been in storage since 2002. Just paid the reg fees 1976 car in great shape |
elswick |
I might have what you are looking for 1976 fuel injected car in great shape and runs well. Red color and very clean I do want $6000
slugmika |
Hi elswick,
what does that smog cert means? Can it be used temporarily before shippint to Finland? Any pictures? Regards Mika |
elswick |
![]() ![]() ![]() This car is a 2.0 fuel injected car, interior is clean and just a couple of dash cracks but has cover for it also, breaks and rotors ar in great shape. The motor was rebuilt and absolutely no smoke from car or leaks |
Chevota79 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None ![]() |
If you do not want to worry about the smog certificate you can go to the DMV and get a red sticker to put in the window. This red sticker is a temporary registration and is usually good for a month or two, which would allow you to drive it around no problem.
Josh |
elswick |
thanks Josh I will try that
slugmika |
I'am coming 29th of October. I'am staying in Hollywood, where are you located?
Mika +358505932142 |
elswick |
I am in Woodland Hills which is about 20 miles from Hollywood. Car is getting the emission controls fixed for smog test this week and will be registered in less than a week if all goes well
Lo-Fi Version | Time is now: 25th June 2024 - 05:59 PM |
