Rear coilovers - washer/bumper setup, Does this look about right? |
Qarl |
Jan 30 2004, 08:40 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have the aluminum had (which sits in the spring).
On top of the shaft is a large flat washer, that only goes to a certain point, because the shock shaft diameter increases) On top of the large flat washer are the two rubber pieces with the internally threaded sleeve. On top of that is a smaller washer And then the locking nut. Will this work? (and I'll ziptie the spring to the hat too!) Attached image(s) |
Qarl |
Jan 30 2004, 08:42 PM
When I assembled my front struts, I cut down the rubber bump stops (per recommendations from SmartRacing),
Anyways, I utilized the two leftover pieces as bump stops for the rear shocks. Of course, if I ever bottom out that much, then I'm probably screwed! Attached image(s) |
DNHunt |
Jan 30 2004, 09:28 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Karl
I can't see a thing. Did Andy help you take the pictures? Not sure I could help you if I could see. Maybe I shouldn't have celebrated fixing my exhaust leak. I think I'll take a look at it in the morning Dave |
Zeke |
Jan 30 2004, 10:52 PM
Never left, but not right.... Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Karl, the rears are Koni Sports with Smart Racing collars?
Qarl |
Jan 30 2004, 10:58 PM
Bilstein sports, with adjustable collars from Patrick Motorsports (they probably get them from SmartRacing).
ChrisReale |
Jan 30 2004, 11:09 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
ask Chris Campbell, he had some issues with his Bilsteins and coil overs. Or, just be like the rest of us and get some Koni"s (IMG:style_emoticons/default/laugh.gif)
DNHunt |
Jan 31 2004, 06:47 AM
Now that I can see this morning (better monitor than my laptop), the rubber at the top looks right to me. Course I've only done this on my car. I like the collar on your setup better than mine. Mine has the set screw going directly against the threaded sleeve. Eventually it will ruin the treads. Got mine from Jason at Paragon.
Dave |
Lo-Fi Version | Time is now: 25th June 2024 - 09:53 PM |
