914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I am going to sell a 1973 body with title that I have had in the garage for 15 years. Here is the details:
factory steel flares installed: buttwelded and filled with lead and skimmed front fender seams filled with lead and skimmed new trunk hinge mounts new battery tray assembly 10 piece strenghting kit Good: Body is straight and never been hit (ding around drivers headlight bucket) 2.0 L car with factory app group and stabilzer bars good longs minimal floor pan rust minimal back wall rust minimal trunk rust hell hole is good but patched only in the bottom Bad: Needs triangles right suspension arm has been repaired passenger side pan and bottom of long need repair split in inside long by handbrake front fender rust bottom pass door jam What is a fair price? Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
914Sixer |
More pictures of bad:
Attached image(s) ![]() ![]() ![]() ![]() |
914Sixer |
No opinions?
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Hi Mark,
Is this just for the roller or does it have a drivetrain? -Rusty |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
You're going to lose just selling the body....specially since the rust wasn't repaired prior to the paint.
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
You're going to lose just selling the body....specially since the rust wasn't repaired prior to the paint. Unfortunately, (IMG:style_emoticons/default/agree.gif) As a result of the long issues, I would bet you won't get more than a few hundred dollars out of the tub. Which is really too bad, as the money spent on the flares has to be way above that. (IMG:style_emoticons/default/sad.gif) Eric Read |
Joe Bob |
I just did a suspension ear repair on a 914/6 The rack time and parts ran me $1500.00.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,734 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'd opine it's somewhere between $1000-$2000, which doesn't tell you much, and I'm sure you've got more than that into flairs and paint.
I'd flog the body guy for painting a car way before all the work is done. You just can't leave that kind of rust and then paint the car. There's just too much backing up to make the chassis right. With all that leftover rust, I'm thinking "how good and correct is the suspension console repair?" Sure it could be perfect, but the remaining rust holes will cause speculation. Regardless how well the flairs were put on, the undones will over rule. Good luck! |
914Sixer |
Car was left in limbo at one point due to wifes death. It sat outside for a year under a tarp, the rust appeared at that time. I never really noticed the suspenion arm repair until last year. I am at a crossroads with car. I will need to repair the rust and pay for another paint job. So far I have $4.5k in paint and body work not counting the price of the car.
Lo-Fi Version | Time is now: 23rd June 2024 - 01:22 PM |
